Mea # for goodman gch95 - Heating & Cooling
  • airworks91 Mar 21, 2011
    Don't understand what you are looking for? MEA#?
Why does new furnance with propane conversion have yellow flames?
Make sure the kit included smaller sized orifice's and spring kit for the gas valve. The number on each orifice should be cross referenced with total btu's rating of the furnace. It does seem like there is too much fuel or not enough air intake (combustion air). The inches of W.C. seem fine, but you still may be getting too much volume of fuel with too large of sized orifice's. Hope that helps
Dec 20, 2013 | Heating & Cooling
1985 Plymouth Voyager 2.6 L failed NOX emission test
1) please RUN the scanner and computer test from any repair shop you must get the exactly faulty in your emission system
2) However you can go to the www.automecanico.com+ www.autoelectronico.com this sites is in spanish, but you can translate with your web browser and I Higly recomend because has Powerful information update for any cars models, Try it and fix it.
God bless you
Jul 09, 2012 | 1985 Plymouth Voyager
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Oct 17, 2017 | 1993 Ford Taurus
Need 92 toyota paseo to pass CA smog test ! What causes too high HC in smog test????
High HC means moisture in the system. Try driving it longer then take it to the smog shop. Otherwise it could be hard like a head gasket or easy such as a PCV not functioning. Any ways you should always drive it about 20 miles before smog check, longer when the weather is cold.
Nov 30, 2010 | Toyota Paseo Cars & Trucks
1991 Honda Accord LX failed EVAP test. The ASM Emission Test Results showed Test 25mph RPM 1933, %C02 MEAS 14.60, %02 MEAS 0.22, HC (PPM) MAX 61, GP 236, MEAS 19, CO (%) MAX 0.60, GP 2.10, MEAS 0.02, NO...
Things to consider or replace...
If you are getting a Check engine Light let me know, it will make things easier to diagnose.
Catalytic Converter
Oxygen Sensor
EGR Valve
May 17, 2010 | 1991 Honda Accord
Failed Emission Test with high NO(PPM)
Sort out the fuel/air mix and check for oil burning or replace the van.
Sep 17, 2017 | 2000 Saturn Ls 4dr Sedan
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
