Question about Tally T6218 Matrix Printer
All my tractors are okay but my printer still giving me a paper motion error?
  • Matata Mwas
    Matata Mwas Jun 05, 2012
    do the paper alignment and check whether the platen is tight
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
You need to clean paper motion sensor first,
check its connection on logic board
clean the connector of sensor,
if you can then please post u r problems with printer model then i can explain it more.
Posted on Jun 05, 2012
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
Paper moving fault
If the paper is moving freely in the printer and you are not experiencing any paper jams etc it may be possible the error is being indicated falsely.I would recommend firstly to ensure the tractor feeds on the printer are clean and free from a build up of paper dust etc. As the paper motion sensors are located on the tractor feeds.
If after the printer is cleaned the error is still see the problem may be related for a setting for the Paper Motion Threshold in the printer. this is the point at which the printer detects an error. This value is dependant on a number of factors; Paper Type, condition of the printer etc.
  1. Put the printer OFFLINE
  2. Press and Hold down LINE FEED and ENTER until TECH ACCESS ON is displayed (approx. 5 seconds)
  3. Press the MODE button
  4. Press the DOWN ARROW until TEST is displayed
  5. Press button 1
  6. Press the DOWN ARROW until DIAG is displayed
  7. Press button 2
  8. Press the DOWN ARROW until PMOTTHR is displayed
  9. Press button 3
  10. Press the Either ARROW to set the value to 170 and then press ENTER to save the value.
Once you have completed the above sequence press and hold down the LINE FEED and ENTER KEYS to turn tech access off, you can then test the printer. If the above does not clear the message try increasing the value further.
If the problem persits you may have a faulty paper motion sensor.
Nov 23, 2011 | Tally Line Matrix T6050 Printer
Show the load paper error
There is a paper motion switch behind the tracter feed assembly that might be stuck. Check that and also clean arround the tractor assembly.
Jan 01, 2009 | Printronix Line Matrix P5005B Printer
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
Error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
Epson lq 2080 printer problem
These steps apply to a Windows system.
1. Click on "Start", "Settings", "Printers".
2. Right click on the icon for your printer and left click on "Properties".
3. Click on the "Paper" tab. Here you should see a "Paper Source" option.
4. Make sure that "Tractor" is selected and not "Manual" as the paper source.
5. Once this change has been made click on "Apply" to save the change.
6. Now try printing a document.
Apr 26, 2008 | Epson LQ 2080 Matrix Printer
Tally T2250 Matrix Printer does not pull up paper to be printed
I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
To do this;
  • Stop any prin jobs gong to the pritner
  • If the printer has data in its buffer, power the printer off and back on again to clear this data
  • Ensure the printer is OFFLINE
  • Press the SETUP button
  • Press the button under ADJUST
  • Press the button under PAPER WAY
  • Use button 2 or 3 to change this to TRACTOR 1
  • Press SET
  • Place the pritner ONLINE
You should be back in action, if not post the message you see on the printers LCD display.
Dec 18, 2007 | Tally T2250 Matrix Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally T6218 Matrix Printer Logo
62 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
mohamed salim shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
