Question about GPS
I have a problem with my Mitsubishi lancer 1998. My odometer does not work when the car heats up. It okay when it's cool in the morning. Please advise.
  • 2 more comments
  • plee1962 Mar 21, 2011
    Speedometer, temp and petrol indicator are not working. Signal and gear lights are working.
  • plee1962 Mar 22, 2011
    Where is the supply coming from to the instrument cluster. It's it from a relay or a fuse. Do you have a circuit digram of the instrument cluster? Suspect no supply to the speedometer/odometer but all globes are on???
    Thanks for your respond. After removing the instrument gauge many times, now the speedometer/odometer and fuel gauge are not working even on cool days. looks like it's an intermittent problem somewhere.......not sure. Will get an instrument gauge from the wrecker and try it out. Hopefully it does not cost too much.
  • plee1962 Mar 24, 2011
    Solution is helpful but problem still unsolved.
  • 19,396 Answers
Hi.
That is likely a faulty instrument gauge. The wires and speedo cable to instrument gauge must be checked from the back of the gauge. If the rest of devices are working there is no point in testing from ignition, or from relay board.
Removal and testing are the same as the ones illustrated here for a Colt from same years. Check from page 23.
Posted on Mar 22, 2011
  • Ginko
    Ginko Mar 22, 2011
    The intermittent failure would point at a wiring problem. The point is that if the problem occurred only when hot, and if it is only one gauge, it is more likely an electronic problem. Wiring goes with vibration, not with heat.
    Problem can also be the sender, it must be tested, see the service manual.
    President:
  • 1,702 Answers
The odometer is driven off the speedometer, if the speedometer works then there is a problem with the drive to the odometer it is an internal part of the speedometer and is not serviceable you will need to replace the speedometer in order to repair your problem.
let me know if there is any thing else i can do for you.
Posted on Mar 21, 2011
  • john nail
    john nail Mar 21, 2011
    all of these gages get ther power from the same place a thing caled a quad driver in the insterment cluster, it is also not serviceable, you will need to replace the insterment cluster in order to repair your problem.....sorry
Where is port obd-ll in mitsubishi lancer 1998
Mitsubishi Lancer OBD 2 port is on lower right corner dash; next to console kick panel
Jul 25, 2014 | 1998 Mitsubishi Lancer
Runs o.k in the morning.When parked in direct sunlight or in hot temperature ,loses ;odometer ;speedometer;petrol level indicator on dash
The instrument cluster board might be heating up and shorting out signals from what you destribe. Look for cracks in the board and solder on the board and see what you find. You might want to try a new instrument cluster and see if you have the same problems (possibly get a used one). Let me know what you find.
Benjamin
Nov 04, 2010 | 2002 Mitsubishi Lancer
I have no heat in my 2003 Mitsubishi Lancer. When
The cable that pulls the cool/heat switch on the a/c gets weak and it doesnt allow the dial to switch over to heat. You can see that cable and the way its supposed to work on the right side of the gas pedal over it. I usually just use my foot to push that switch over to heat and reach with and pull on it with my right hand to cool.
Jan 08, 2010 | 2003 Mitsubishi Lancer
Problems with lancer MR speedo revs and odometer
exact same problem happened with my lancer i took it to an auto instrument shop and it cost me $330 to fix and hasnt stopped working since.
Oct 14, 2009 | 2003 Mitsubishi Lancer
Speedometer, odometer frozen
there is a steel braided cable located at the back of your speedo panel that connects it to the tranny, this cable rotates from the point it connects to the tranny and transmits it to your panel. this cable may have snapped. pull out the panel, take out the cable and replace.
Sep 02, 2009 | 2003 Mitsubishi Lancer
99 lancer,speedo tacho n gauge problem.
probably burnt or cracked circuit board on back of gauge cluster
Jun 21, 2009 | 2002 Mitsubishi Lancer
Lancer 1999
i have repair this problem many times remove your cluster and the printed circuit board requires replacing
once you have replaced the printed circuit board the cluster should work
NOTE: remember how the bulbs and screws came off the back of the cluster i would usually make a picture out of it on the table where im working on
Aug 06, 2008 | 1998 Mitsubishi Mirage
GPS Logo
151 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
