Question about HP Designjet T1100ps Printer
HP designjet t1100ps error 21:13 - HP Designjet T1100ps Printer
  • HP Master
  • 1,915 Answers
This is a service station error indicating that the printer could not move the pirnthead mechanism over the service station. First check to see if there is anything in the carriage path such as a piece of paper blocking the carriage. If there is not then it is likely a bad service station that will require replacement. Always try powering pirnter off then on to see if it was temporary error.
Posted on Mar 21, 2011
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
I had the same error with the T610, and it turned out I just replaced the belt, but when I replaced the belt I moved the encoder strip alignment around. When I entered the service mode I observed the service station move in and out as its suppose to but when it was suppose to move the print head carriage back to the home position I got the 21:13 error, but then I realized it might be that it wasn't able to tell the carriage to move to the home position because the encoder strip was misaligned which caused the 21:13 error, so I looked at the ends of the encoder strip with a flashlight and realigned the encoder strip in the center of the carriage slot from each end with the arrows on the carriage and now no more error and everything works. It was when it tried to move the ink carriage to the home position that the error occured, and that the encoder strip was out of alignment. There are arrows just above the encoder strip on the carriage.
Posted on Oct 19, 2013
  • 917 Answers
Error 21 usually refers to the Service Station. Try the following (from the service manual):
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer.
Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station.
Perform the Service Station diagnostic test to troubleshoot the problem further.
If the above does not work you may have to replace the Service Station or related mechanics.
  • 96 Answers
SOURCE: The HP DesignJet T1100ps printer has a 79:04 error
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Posted on Oct 01, 2009
SOURCE: HP 800 designjet plotter Error Message 21:10
need to replace service unit
Posted on Mar 22, 2010
  • 217 Answers
SOURCE: hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Posted on Jul 29, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: hi hp designjet t1100ps plotter showing
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Posted on Apr 02, 2011
vinay229229
  • 1121 Answers
SOURCE: HP Designjet T1100ps 44-in Printer
Recommended for tec guys only:Error indication that service station error, open right cover check is there any obstacles in service station movement?.. check the service station connectors, if feel every thing is fine, remove service station, found dirty? remove motors, remove service station cover, clean entire unit with water, ensure that stocked ink entire should washed out, allow service station to dry, fix it up, apply grease for moving parts, fix entire back then try....for confirmation do the service test..** cleaning service station is dirty work but it will give good mileage, while cleaning take care of sucking tubes & drop detector unit.. Best of luck..
Posted on Nov 19, 2011
How to install New firm ware in new hard disk printer hp designjet T1100Ps
When you installed the new hard drive, was it purchased from HP as the hard drive for the T1100ps, or did you install a generic hard drive like for a laptop?
HP uses a special formatting on their hard drive with its own operating system with the latest firmware already installed (not windows o/s), so just installing new firmware will not work...the plotter must be on and in a ready state to receive the firmware update.
Sep 24, 2013 | HP Designjet T1100ps Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Apr 28, 2012 | HP Designjet T1100ps Printer
HP designjet 90 error code: 22.10
System Error: 22:10
Ink Supply Station failure.
Corrective Action: Replace the Ink Supply Station
(The Ink Supply Station is the mechanical part under the ink cartridges.)
Jun 13, 2011 | HP Designjet T1100ps Printer
Error 8:11 HP Designjet T1100ps 44in PS3
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part..
d4wd6icgpc9laaaaaelftksuqmcc
nloqafiqpfr0pqy6fgsl6z+nlcjwrqeuxlt5siey8sjpc+feblil6+xgwjruzafracof0e359teuwi1ozhlmhrx0xfmcd+bfeilmn5l+ppik2hpic6wgwvpqfwee1yw0nvg1qi9vzo58bnigp4octvkvtsy87834sjn6odbsmoha2eycmv8comsjb7raqh4aaaaasuvork5cyii=
May 03, 2011 | HP Designjet T1100ps Printer
Hi hp designjet t1100ps plotter showing error code 86:01, paper jam. but physically there is no paper or obstacle in print area. carriage block also moving one time right to left then the error code is...
Apr 01, 2011 | HP Designjet T1100ps Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
HP Designjet T1100ps Printer Logo
6,879 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
