Question about Panasonic Heating & Cooling
Need servise manual for cu140c53xp air conditioner 13 kw
2 Suggested Answers
  • 108 Answers
SOURCE: Split System Air Conditioner Model
Enter the name of the unit into your browser. It will ask for a model #. Enter that. All the info you need should be displayed. (I can tell by the model# your unit is 3 ton. Rule of thumb; 10 amps/ton Therefore 6.2 KW)
Ray
Posted on Nov 11, 2008
  • 587 Answers
SOURCE: How can we caculate the energy needed by an air conditioner?
It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
Example 35000 btus / 2500 watts = 14 EER
If you know the capacity,btus and EER you can calculate the watts, capacity / EER
Example 35000 btus / 14 EER = 2500 watts.
EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
Posted on May 15, 2009
Download 5.2 kw moretti cooling only air conditioner manua
Tough One
Couldn't find it here
http://homeappliance.manualsonline.com/manuals/device/air_conditioner.html?page=5
I think I saw the Manual HERE
http://homeappliance.manualsonline.com/support/other/air-conditioner/air-conditioner-5415960
Mar 02, 2015 | Heating & Cooling
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Hi, Yesterday I bought haier 12000 BTU air
To determine the cost of using this air conditioner, you will need to find out what your electric company charges per kw/h. This is the standard unit that electricity is charged for. Next determine the wattage of the air conditioner. This should be found on the unit name plate. If you can not find the wattage by the name plate, the take the voltage and multiply by the amperage, this will give you watts. Next multiply the wattage by 24. (watts per hour x 24 hours) Finally divide this number by 1000. This will give you the total Kw that the unit will use in a 24 hour period. If you multiply this number by the cost per Kw that will give you the operating cost of your unit for one day.
ex. electric company charges .25/Kw The unit uses 1000 watts 1000 x 24 = 24000 watts 24000/1000 = 24 Kw 24 Kw x .25/Kw = $6.00 day
Note: all figures shown above were randomly generated in my head, and have no correlation to your calculations. Hope this helps.
May 04, 2010 | Heating & Cooling
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
Need new one
Air conditioner equipment power in the U.S. is often described in terms of "tons of refrigeration." A "ton of refrigeration" is defined as the cooling power of one short ton (2000 pounds or 907 kilograms) of ice melting in a 24-hour period. This is equal to 12,000 BTU per hour, or 3517 watts.[13] Residential central air systems are usually from 1 to 5 tons (3 to 20 kilowatts (kW)) in capacity. To determine the correct size keep in mind that 12,000 BTU's equals 1-ton. Use the table below to determine the size AC that you need. Hope this helps. Area To Be Cooled (square feet) Capacity Needed (BTUs per hour) 100 to 150 5,000 150 to 250 6,000 250 to 300 7,000 300 to 350 8,000 350 to 400 9,000 400 to 450 10,000 450 to 550 12,000 550 to 700 14,000 700 to 1,000 18,000 1,000 to 1,200 21,000 1,200 to 1,400 23,000 1,400 to 1,500 24,000 1,500 to 2,000 30,000 2,000 to 2,500 34,000
Jan 08, 2010 | Intertherm P3RA-048K Air Conditioner
Manual
The manual can be downloaded fee.
Here is the link:
http://www.sylvane.com/images/productpages/DeLonghi/Air-Conditioners/kw85/KW85.pdf
May 18, 2009 | Kenwood KW85 Air Conditioner
May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
Split System Air Conditioner Model sn:QC136AUP(QC136EXU)107034-73 What six=ze is it ? what Kw?
Ray
Nov 11, 2008 | DeLonghi Heating & Cooling
Heating & Cooling Logo
231 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dan Webster
Dan Webster
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
