Question about Vacuums
How much will it cost to replace a leaking pump or is it best to buy a new washer
    Novelist:
  • 185 Answers
I am assuming this is a washing machine. Not knowing the model, most machines have the pump underneath it and it is accessible if you can set the machine on its side. Make sure that the water is drained out of it first. You might want to take it out to an area where a spill of water from the machine won't matter. The pump is connected with two hoses and it can be belt driven or mounted directly to the motor. It is not too difficult to remove and replace. Having the part with you when you go to purchase a replacement is good. Be sure to take photos before you remove the pump. This will help the memory when you go to install the new one.
Posted on Mar 21, 2011
Hose diagram for a bissel pro heat 2x complete pet
This is tricky... I'll suggest that you put the hoses back on EXACTLY where you took them off from. If this does not work, save all the parts, a competent technician will be able to reassemble your unit for about twice the cost of buying a new one.
Mar 18, 2016 | Bissell 8930M Upright Steam Cleaner
Would it be easier to buy a new one or fix it? I've had it for over 7 years
Hard to say. No make/model provided. How much did you pay for it new? How much would it cost to repair? If there is little difference between the two prices, may be best to buy a new one.
Mar 12, 2016 | Vacuums
Unit is leaking at the bottom of the pump
what sort of pump are you on about
washing machine , dish washer, garden, tank , well
All have varying pressures at the outlet
Feb 20, 2018 | Oreck XLS700A Upright Vacuum
Hello. so i have a 1/2 HP sta-rite pump. a while back it start making a whining nose. im curious is if it makes more sense to buy a new pump or buy a rebuild kit. thank you
Hi mwsang...
It would be cheaper to buy the bearings and replace them as this is causing your whining noise.
When you get the pump motor apart then you can take the bearings off the rotor and take them to the nearest bearing shop for replacments.
Replace your bearings and it will be good for a long time again.
Please take time to rate me
Aug 28, 2011 | Vacuums
My steam vac is leaking water. It still works, but how do I fix it from leaking out the bottom?
It cost me $65, had to buy a new clean water bucket. If you shine a light on the bottom you will see a shatter effect much like broken shatter proof glass in car windows, apparently it is cheap and doesn't last. Who knew?
Jun 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My microwave appears to work in all aspects except the important one, it is not heating. It is 7 years old. Is this repairable or does it need replaced?
probably a blown fuse. i would not suggest fixing yourself as there are extremely dangerous voltages inside. to have service shop fix would cost 80 to 100,m prob best to toss and buy new.
Oct 18, 2010 | Vacuums
Is there a cheap battery replacement Black and Decker PHV1800
Hi pwolft...
Amazon offers pretty large number of black decker replacement batteries, click here Finally charging for our multi device world and pick one (which fits).
Hope this was helpful.
enjoy
Jun 13, 2010 | Black & Decker PHV1800 Bagless Handheld...
Bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
Aug 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Eureka Wide Track Superlite Vacuum
Eureka doesn't make these motors available. Best to just replace the stick vac with a new one.
Jun 14, 2008 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Hi my vacuum (Russell Hobss 2200 bagless HEPA) seems to have just enough ( not loads) of suction til it reaches the cleaning head. the head does not appear to be blocked - but there is then almost no...
Generic problem for all Vacuums
Hi my vacuum (Russell Hobss 2200 Bagless HEPA)
Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all.
It also makes loads of noise when on- and an even louder noise when turning off.
is it fixable or is it dead?
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one.
Don – The Vac Man
Apr 21, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
