Question about Dell Computers & Internet
When i start my dell d610 once in 10 times vertical white lines appear at very first instance even before bios setup info, what could be problem. its with 2ghz pentium m, 1gb, nvidia graphic adaptor
    Genius:
  • 1,400 Answers
Hello
Try a new monitor to video card cable,or check for a loose connection between the two.
Next if you have another monitor see if it happens again,possible the monito may be going bad.
Posted on Mar 21, 2011
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
Win 7, Samsung LCD, initial BIOS display. Then vertical lines. If choose BIOS setup also scrolling vertical lines (looks like barcode) Thank you!
If the lines appear in the BIOS (Basic Input Output System) setup, you are having problem with the LCD.
Here are some parts to check. Either you need to reinsert or replace.
- LCD cable
- LCD inverter
- LCD itself
Note: The LCD inverter fails often than other LCD assemblies.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Help i have a dell inspiron 530s and all of a sudden my keyboard and mouse do not work on when the logo of windows comes on in start up nor the mouse or keyboard work but my keyboard works on f2 and f8...
Try restoring your system bios to factory default and this may fix your problem. If not- post again with results and we'll go from there.
Entering System Setup
Turn on your computer.
When the blue DELL logo is displayed watch for the F2 prompt to appear (black screen / white text).
Once this F2 prompt appears, immdiately press F2 .
The F2 prompt indicates that the keyboard has initialized and is detected. This prompt can appear very quickly. Watch for it to display as the screen powers up, and then press F2. If you press F2 before you are prompted, this keystroke will be lost. There is a small window of time to do this before Windows starts.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then, shut down your computer and try again to enter setup. At setup check your bios version. It may need to be flashed (upgraded). Select load factory defaults to see if that will resolve your PCI issues.
Jan 16, 2011 | Dell Inspiron 530s Desktop Computer
How do I program my latitued lap top so it gors directly ine to the windows sart up , instead of having to enter a pass code to go thru the bios program. Once I eneter the bios pasword it will activate...
It seems that the Dell is not publishing the BIOS reset info online. You can try following the below steps once. ( Article ID: 184659)
During the initial boot of a computer the BIOS supplier will be displayed. If OEM logo splash screen is displayed, press ESC key to see the boot up information. Press the Pause/Break key if text displays too fast.
In the BIOS window, select Security tab and delete the BIOS password.
Jul 04, 2010 | Dell Latitude D610 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Black and white lines after bios screen before boot up
The issue appears to be cosmetic if the system boots to WIndows and there are no display issues using the system. Some systems I've seen have a bit of video distortion between the BIOS splash screen and the desktop. A couple things may change that. Update the system BIOS and the video driver to the most current available
May 23, 2009 | Dell Latitude D610 Notebook
Need to know what the Fkeys stand for. Bought this computer used and am not sure what keys stand for.
here are some of the keys
http://support.dell.com/support/edocs/systems/latd610/en/ug_en/keyboard.htm#wp1054091
here you can see the entire manual for your laptop.
http://support.dell.com/support/edocs/systems/latd610/en/ug_en/index.htm
May 01, 2009 | Dell Latitude D610 Notebook
Thin vertical lines on screen
You need a new LCD screen.
Thats a common problem with those panels
Or can be a hardware defect that occurs when the screen wasn't properly tested at the factroy
Nov 23, 2008 | Dell XPS One All-in-One TV Desktop with...
Computers & Internet Logo
74 people viewed this question
Alun Cox
