Question about Vulcan Kitchen Appliances - Others
I have in my possession a braising pan skillet G40TB.This system the pan needs to be lifted to light the pilot. When i light this pilot and lower the pan, i will normally wait for 10-15secs, turn the thermostat on, depress the red button which takes gas to the tube line to the burners. The problems are:\r\n1. When i depress this button after a couple of seconds a explosion sound is heard when the burners ignite. 2. when the temperature reaches the point of the setting set by the thermostat the flame goes out on the right side segment of burners. When the system calls for heat, a repeated explosion tye sound is heard. This happens every time the need for heat is required. 3. When the pan is in the heating mode, the right side segment of the burners fail to light, even if the red button feeding the tube line to the burners is depressed. My suspician are: the orifice on the tube line may be restricted or the wrong start up instructions are being followed. PLEASE ASSIST
    Genius:
  • 1,015 Answers
It sounds to me like you are following the proper start up. I would recommend that you do as complete a disassembly as you feel comforftable with and carefully clean all pilot and burner orifices.Clean all grease and crud out with a good degreasing detergent,I have used dawn dish soap for years. After you get everything as clean as you can gently wipe it dry and blow out with low pressure compressed air.Also clean out all gas lines and make sure the air shutters are set so that you have a nice blue flame with a small bit of yellow.I hope this helps you.Thanks
Posted on Mar 21, 2011
Braise cook chuck roast
http://www.cooks.com/rec/search/0,1-0,chuck_roast_dutch_oven,FF.html
Mar 05, 2015 | Kitchen Appliances - Others
What would be the solution to fix the item if the error code the item is giving is "flame rod short"? the item will not turn on.
This probably means that the flame sensor is shorted to Ground. This sensor is usually a flame rod that is partway into the flame and detects a current flow through the unit. Unplug the braising pan.
Check the wire between the flame rod and the control unit. It may have damaged shielding or be touching another part of the braising pan. Replace the damaged wire. Next you need to check the flame rod is in the correct position. It will be mounted near the igniter or pilot light. Then the rod needs to be partway into the flame. Sometimes moisture gets into the unit; this can be dealt with by cleaning the flame rod with steel wool. (Remove it first.) Next check the rod for damage and replace it if there is damage.
You may want to have a professional check the unit. If the flame rod ceramic housing is damaged, that should be replaced by a professional. If the rod isn't correctly positioned, the braising pan could become hazardous.
I hope this helps.
Sep 08, 2014 | Vulcan VG40 Gas V Series Braising Pan - 40...
Where is my pilot light for kenmore 317B6442P001
it shouldnt have a pilot light
there is a hot surface igniter under the pan below the racks
two screws in the back then lift from back (tabs in front)
is the oven not working or lighting?
you cant light with match or lighter
if you are having problems lighting change the igniter
simple to do 15 min get part un piug old plug in new
Nov 18, 2013 | Kenmore Ovens
We purchased a used Vulcan Steamer model # VSX10GC which was set up for propane. We need to convert it to Natural Gas. How do we do this and how do we get the parts
Please be careful when converting appliances form natural gas to propane. Depending on the equipment there are several changes that need to be made. You will at least have to change burner orifices and convert or replace the gas valve. Some gas valves are not convertible. What many people over look are changing the pilot orifice and on some appliances like braising pans, griddles and char broilers there is a runner tube orifice. The gas valve also needs to be adjusted to the proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Mar 11, 2011 | Vulcan Hart VSX5G Counter Convection...
Do the thermostat contacts attached to bimetalic strip & other strip within plug of the NON-digital Rival skillet erode over time and become thinner? - Friend's skillet (took appart temp. probe plug)...
Hate to write answer to my own problem, but after showing (its THAT SIMPLE folks!) the innards to my wife, showing her how contacts do not move close 'nuf together to touch until dialed to 300F, she said, why not put a block under lower stip to raise it. Was about to, when I noted top strip appears to be merely spring steel, and she was advocating propping up the thinner lower BI metalic one, which would have stopped it from flexing as it must as temp of pan changes. SO, we brainstormed it, used her little jewelry needle nose pliers and alternately bent top (spring) strip down and lower (bimetalic) strip upwards with knob set at "warm" until they were TOUCHING, but nevertheless would separate when knob turned fully to "OFF" Since this thermostat pilot light works whether hooked to a pan or NOT, we plugged it in (no danger, probe is not electrified in any way unless maybe handle is dipped in water and salt!) and saw that light goes "on" at warm, off at "off" and further, that when we set it at 200F and hold a lighter under the probe (it is just hollow metal, not a precision device, simply conducts heat to metal strip inside) it turned off properly at what we guess is pretty close to 200F. Will add an addendum "solution" comment when we return thermostat to friends pan tomorrow and cook something!! No electrical degree, just a wife who got tired of me not fixing her firends pan and started unscrewing things until I got aggravated nuf to do something w/ it. Happy New Year. "He who finds a wife finds a good thing." -bible
Jan 03, 2011 | Rival S16 Electric Skillet
Heating element won't heat. Control light comes
your element is shorted
since the elemen t is welded and fitted to the bottom of the pan it can be fixed but should not be
my advise get a new one
rival will just say it has water damage
Oct 08, 2009 | Rival S16RB Electric Skillet
Rival electric skillet # S16g-CN
I have just taken apart the probe / thermostat of this model for a friend. I am an amateur, but it is such an amazingly SIMPLE piece of equipment (in the non-digital, i.e. mechanical thermostat model I'm looking at, that it is clear that the light will be "on" if the thermostat is sending electricity to the heating element, WHETHER OR NOT the element is broken or even connected to thermostat: In other words, if the light is not going on with thermostat knob in any position but OFF, the problem is with the thermostat: The pilot light goes on even if thermostat is NOT PLUGGED INTO the pan; when functioning properly, which one can observe on working pan even w/o taking it appart. But if you have digital model, this will be of less sure use to you, tho the way two yellow wires go to pilot light INDEPENDENT of power returning from pan itself, it suggests the same may be true with all their models.
Nov 29, 2006 | Rival S16 Electric Skillet
Kitchen Appliances - Others Logo
48 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
