Question about Transcend Computers & Internet
Hello, my storejet 160gb hard disk is not accesible now. just after the insertion in the pc it is failing in completing the auto play function and when we try to open/explore by clicking on the drive one error shows " drive is not accesible : , the file or directory is corrupted and unreadable ".. pls help ..
  • Brian Sullivan
    Brian Sullivan Mar 21, 2011
    i am unable to post this answer it says invalid characters try again so i have to answer it using this
    Attach 160 GB transcend click start control panel administrive tools computer management disc management you can right click select properties tools check now tick in both boxes to scan for and repair recover any bad sectors and automaticall fix any corrupt files or tick in one box then return after it has fixed the first task then tick the other box also make sure the leads are securely seated and are not bad faulty a bad lead will give you this error message
    hope this helps
  • 55 Answers
There are 2 solutions for your problem, but both of them request advanced knowledge in hard drives arhitecture and computer operating. First solution works under windows and is called Victoria 4.3 for windows. It's a tools for diagnostic and repair at low level for hdd and you can find it free on the internet, for these method you can use your hdd conected to usb, second it'a also free and it's called MHDD and you can find it at www.hddguru.com, for these method you must remove hdd from the enclosure and connnect it directly to your computer motherboard and boot from the cd created with MHDD, but be very carefull, you can destroy your hdd permanently if you don't now what to do, and you can lose all your data, so if you have an IT specialist ask him to do it.
Posted on Mar 21, 2011
    Problem Solver:
  • 15 Answers
If you have a hard drive that is corrupt of failing sometimes running check disk will recover some of the files or repair the problem, follow these steps
start type cmd in the search bar or run prompt type the drive letter follow by a colon and hit enter type cd backslash and hit enter type chkdsk space front slash r
the backslash space are actions or symbols that need to be typed in. i get an invalid character error when i try to include them here.
this will fix any errors and try to recover any files from bad sectors also if it is a mechanical failure with the hard drive sometimes putting it in the freezer for several hours will allow you to access the information because the cold shrinks the metal. its a long shot but has worked for me before
How do I get auto play when I insert a blank disk to pop up?
Go to :Control Panel" then look for the icon "Auto Play" click it self explanatory from there
Jun 17, 2014 | SIB DL USB External DVD±RW Drive for Dell...
No bootable device --insert boot disk and press any key
Sounds like your hdd has crashed. Look for a replacement hdd.
Feb 02, 2014 | Acer Aspire 5315-2326 Laptop Computers
Where can I get a start up disk for my asus laptop, when I try to boot up I get: The boot selection failed because a required device is not accesible
The hard disk may need reseating or it may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
May 06, 2011 | ASUS G1SN-A1 Gaming Notebook PC
I have my StoreJet 25M 640GB external HD. I was transferring files from mycomp to the StoreJet yesterday when suddenly the transfer stopped( I was transferring video files, it happened 30mins since I...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 12, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend store jet 25 mobile 160GB hard disk...when i connected to laptop it is not connecting.......one button is on Hard dish..if i press the button and hold it upto i put the usb cable in to laptop...
Go to www.transcendusa.com, this is official site for transcend products. You will find there a little program to restore functionality of your hdd (this in case hdd have no bads on disks), run this program and see after that if is ok. Good luck!
Mar 21, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Dropped my super droppable protected 160 drive,now the light flickers when plugging to pc but not working
bro.. this could be because it got disconnected from the circuit inside it...
just open up the casing and you will find a laptop hard disk with a circuit attached to it ..
just try to make the connection firm again by removing the circuit and putting it back again...
InshaAllah it will work fine again...
best of luck...
Mar 02, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Transcend 320GB is recongized as "unformatted"
Here is an article with some ideas on how to solve issues with an external hard disk.
If it does not work, one last option is to take the hard disk out of the case and connect it directly to the SATA or IDE interface in your computer.
Jul 01, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
To backup my data
you can use you 160gb HDD as slave in your old pc. then coppy your files and save it in the old pc HDD. affet you back up your files you can put back your 160gb HDD in your original pc and you can format it now. hope you can use this one.
May 31, 2009 | Gateway 310S (2900621) PC Desktop
Cannot delete files from transcend storejet 2.5 160GB
Is there a physical lock on the device that needs to be switched?
Here are a few things to consider:
  • Only have one Explorer window open.
  • Have no other programs running that might be accessing the files.
  • Right-click the file, click Properties, and see if the write protection is on.
Oct 15, 2017 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computers & Internet Logo
207 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
