Question about Seagate FreeAgent (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive
Internal power supply has failed for the 2nd time in about 12 months, so I am now looking to salvage the HDD from the unit & recover the data to another storage device. Would appreciate guidance on how to set about disassembling the unit, rather than "rip / tear / bust" Thanks in advacne, Michael
    Scholar:
  • 60 Answers
Hope this helps. If it does then please remember to leave feedback.
Posted on Mar 21, 2011
Toshiba e studio 282 call for service f103 . now what should i do?
HDD transfer time-out: Reading/writing cannot be performed
in the specified period of time.
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are broken.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Mar 28, 2017 | Toshiba Office Equipment & Supplies
Toshiba 256se f 104 reset codes
HDD data error
1 Connector and harness check
2 Check if the connector pins of the HDD are bent.
Perform the bad sector check (08-9072). If the check result
is OK, recover the data in the HDD. If the check result is
Aug 30, 2014 | Toshiba E-Studio 256 Digital Copier
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
I have a Samsung HM640JJ HDD. I bought the drive as an external in an enclosure. The drive has stopped spinning all-together. I even tried to put the HDD in my laptop but will not spin. Samsung will not...
If the hard drive can't be detected by your computer, you can try this way.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezing sometimes works to revive a dying hard drive, at least for a short time(Probable just about 20 minutes), but be sure that the bag is sealed tightly so that condensation and ice crystals don't form. Put it in your freezer for 24 hours that will do the trick. While it's still cold, plug it into your computer.And you may be able to view it in 'my computer'.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data from hard drive with data recovery program.
Tenorshare data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
If it fails, you will have to go to a recovery office where supply data recovery service but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
Aug 27, 2011 | Samsung Spinpoint MP4 HM640JJ 640GB 7200...
Many Bad Sectors fat32, trying recovery disk
It sounds like your HDD is faulty, usually a hardrive can operate with bad sectors but still a risk.
My best advice would be to get a new HDD and recover back on to the new one, even if you did manage to recover onto your current one you may still have problems in the future.
I usually only allow a HDD to fail S.M.A.R.T tests 3 times over any given period and then I just replace them.
Thanks
Sep 05, 2009 | Acer Aspire 3000 Notebook
The mini-USB connector has broken loose. Verbatium provides "ZERO" assistance, as they do not provide replacemnt cases or internal parts aside from replacing a failed HDD. I am looking for a internal power...
Alternatively you may be able to resolder the USB port, maybe an electronics savy friend with a soldering iron will help you with this. If you want somebody else to do it for you there is Data Recovery NYC. Also there is good informaation on logic board repairs on hddguru.com.
Jul 01, 2009 | SmartDisk FireLite 80 GB Hard Drive
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
I have to recover fat32 partion with OS & data
Dear user,
Pl Check your format your c: drive or D: drive.
another way you connect your hard disk to another working coputer and pl check your hard drive data by drive.
Regards,
Ravindra Shah
Jun 01, 2009 | Computers & Internet
No power - can I recover the hard drive with my Windows PC?
I just learned the hard way about the way the DMR-E85H manages the internal harddrive. The format information and the table of contents of all recorded video are stored on the unit, not on the HD. I tried the same thing - removed the HD and put it on the PC. Recognized the physical drive but found no partitions and said it was 100% unallocated. I tried a data recovery program (Nucleus Kernel for FAT and NTFS Demo) but it found no file information at all. I have a healthy E85 and a broken one (that I just bought hoping to fix it). I swapped HD's and formatted HD #2 on the healty unit - so I knew that HD was ok. When I put HD #1 back into the healthy unit, the unit immediately wanted to format it (I powered off at that point). By switching drives, the unit lost ALL information about the first drive. Then I put HD#2 back in and interestingly enough, even though it didn't ask to refomat it, the table of contents was gone (there was 1 program I had recorded to test it). So - if you get your unit repaired, it MAY retain the HD info and you will get your programs back. However, the repair may involve clearing the unit memory about your HD and in that case, your drive's data won't be recognized by the E85.
>>> now with all that said, MAYBE there is a data recovery utility somewhere that can extract the video data from the drive - did anything come of the reference to using a torrent client? I'd be curious to know as I still have my HD #1 with program info that the E85 can no longer see. I'd like more info if anyone has it on a powerful data extractor - but otherwise I hope this detail will be helpful. Shawn
Nov 27, 2008 | Panasonic DMR-E85H DVD Recorder
Hard Drive Data Recovery
With file recovery program like asoftech data recovery, hard drive data recovery becomes an easy job. download the program from
http://www.asoftech.com
Dec 26, 2007 | Computers & Internet
Seagate FreeAgent  (ST305004FDA1E1-RK) 500 GB USB 2.0 Hard Drive Logo
81 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
