Question about Sony Playstation 3 (PS3) Console
The connection to server timed out(80710092) ip address succeeded internet connection failed help =(
    Genius:
  • 1,400 Answers
Hello
Try rebooting your router at the pc.
1 unplug all wires to router.including power.
2 Leave unplugged for 30 sec to a min.
3 Plug in all wires then power,wait for all lights to come back up.
4 Try playstation again.
Be sure you have upnp enabled in the router,do this by typing 198.162.1.1 in the address bar of your pc while on the internet.
Username should be admin
Password is either admin or the word password.
Once in the routers home page check settings for upnp and have it chesked off or activated.
Posted on Mar 21, 2011
Error code for sony 3 807
"Hey, here is a list and a reason of some of the error codes you may encounter whilst connecting your PS3 online, also the required ports need to be opened in order to play online.
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation 3 Error Code List
0710102 - DNS Error; No DSN server available.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
80010510 - Will not play hard drive games - Cause unknown
8002b241 - DVI has no audio.
80028EA5 - Unknown
80029023 - Exchanging Key Information exchange has timed out
80029024 - The attempt to obtain an IP address has timed out
80029564 - Downloaded Game will not install - Cause unknown
8002F997 - Can not update XMB firmware
8003051E - Game will not Save
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Press the x button to repair and restore default"
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
80710092 - "An error has occured. you've been signed out from the ps network" - (connection dropped?)
80710102 - PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out.
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond"
http://community.us.playstation.com/thread/2996553?start=0&tstart=0
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
Am trying to connect to the internet on my ps3. I have a Linksys E1000 wireless router. I go through the step by step connection process and It keeps saying: "Obtain IP Address-Succeeded, Internet...
I got every solution in the book and tried them. I learned that the simplest solution is always the best. I was getting the same messages.
Make sure the "Media Server" on your PS3 is set on "disabled"
Make sure that UpNp is "disabled" on router. (I know that previous answer said opposit but I am just saying what worked for me).
The key really seemed to be disabling the media server. Try it and let me know. As I said, I tried all the complex solutions and think it was just the media server.
Aug 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 error code downloading patches. Prior fix-ya advise inop. Need help fixing router problem. Conflict with Ps3.
0710102 - Error DNS, DNS server not available.
8001050B - Don't start demos on the hard disk when you have a Blu-Ray added. Unknown cause.
80010510 - Don't start games on your hard disk. Unknown cause.
80028EA5 - Unknown.
80029023 - Exchange of key information timed out.
80029024 - The Attempt to obtain an IP address timed out.
80029564 - Game downloaded does not install. Unknown cause.
8002F997 - You cannot upgrade the XMB firmware.
8003051E - Game does not write.
80031150 - The settings are not be save. Possible System blue screen "Setting information is corrupted. Press the X button to repair and restore default".
80130203 - PS3 connects to the Internet, but not to the PSN. This could mean that the ports needed to connect to Store are not configured.
80710092 - "An error occurred. You were disconnected from the Playstation Network" - (the Internet connection lost?).
80710102 - PS3 can not start the connection with the information configured with the IP router. Try renice the router.
80710B23 - PSN is offline, or the PSN is too busy to respond.
80710D23 - Off the PS3 for a while (30 min) with the AC switch (not standby mode).
80029024 - "Could not get an IP address."
80028EA5 - Unknown - User cannot connect to PSN. Sony said user to take to get the PS3.
8002F997 - Trying to update the PS3 firmware, downloading the update file for USB and attempt to install failed.
80710016 - Playstation Network is offline.
8013013E - WEP keyError, replace WEP key for all the numbers and try again, or to replace WPA.
8013030F - Check page of the router, off SSID Broadcasting.
8002F994 - Many people are making downloading updates. Please try again later.
80028F10 - Go to Settings and choose presentation HDMI (or whatever your connection) and choose Auto, not Custom.
8002A705 - Unable to connect to. Server. Check the router settings doors.
80030920 - An error occurred during the copy operation. The file may be corrupt or there is a lot of memory. Try copy of its original location.
80010514 - total failure of the Bluray drive.
May 06, 2010 | Computers & Internet
Hi, Im having difficulty connecting my PS3 to the internet via my Orange dongle. I have a crossover cable linking my PS3 to my laptop. And have changed my setting so that my internet is shared through a...
it sounds like u should try going wireless through the internet and cut out the laptop from the situation if u know how to fix the ps3 error 80710102 it will be helpful
Jan 09, 2010 | Sony Playstation 3 (PS3) Console
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
324 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
