Question about Video Game Consoles & Games
I charged my ds over might and I was playing it then it blinked red and turned off and I tried turning it back on but nothing happened
    Sergeant:
    Champion:
  • 218 Answers
Sounds like the battery is not charging properly, Plug it back in and try to turn it on while it is plugged in if it turns on while hooked to the charger than the battery is did not get fully charged for some reason.
Posted on Mar 21, 2011
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
My DS won't switch on
i think your adapter is broken did you see a orange light at the side of the on light place and you gotta charge it for three hours
Nov 29, 2009 | Nintendo DS Console
Is my ds worn out because i didnt play it for like a year and its dead and when i charge it and turn it on nothing happens
Remove the battery and put it back in. If it won't charge and turn on, then you need to replace it.
Nov 08, 2009 | Nintendo DS Lite Console
DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Oct 09, 2009 | Nintendo DS Lite Console
My problem, Its slightly different.
well it depends on how long you havent played it.................if you didnt have it off very long plug the charger in and wait about an hour it should turn on then.......hope this helps
Aug 01, 2009 | Nintendo DS Lite Console
My ds just crashes--shuts down--when playing. Is
The same thing happened to my DS that was 3 years old. But at a point it didn't even turn on. The top screen made a quick blink then it turned back off automatically. I suggest you just get a new DS (I got a DSi) because a new battery is VERY expensive.
Answer:It is definitely the battery, though.
Jul 07, 2009 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on.
i would go to the palce and try to return it if you have a promblem because every nintento has a warranty so you should be able to get a new one.
May 13, 2008 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Ds lite
You never want to play the DS while it's charging, if constsntly persisted it can cause a form of battery leak.
IMPORTANT: Don't charge the DS until it dies on you completely!
When charging the DS the system will display a red light to show it's at its lowest energy, the time it takes to fully charge a DS can take up to 2-3 hours. In the second hour of charging the light will appear green but you don't want to disturb it until the light goes off. ( showing it's energy is full )
Nov 03, 2007 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
