I need the driver to configure my printer - Office Equipment & Supplies
  • Dane Andreasen
    Dane Andreasen Mar 21, 2011
    Please State your Printers Model and Brand to help us assist you.
I can help you with this. Can you let me know what brand and model your printer is?
Posted on Mar 21, 2011
How configure duplexer dell 3110 cn?
You don't really need to configure it as such.
The printer should recognise the duplexer if it is fitted correctly, and it's difficult NOT TO.
Printing a settings page will show the duplexer under Printer Options.
You printer driver needs to be aware of the duplexer, there is an option to 'get information from printer' within the Windows driver.
Once the driver knows the duplexer is available, you'll have an option in the printer driver to print double sided.
Apr 30, 2014 | Dell 3110cn Laser Printer
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I have an Acer 5321-1805 laptop and installed a Medalink version 3.0+ class2 dongle, but I can't print on my hp 6980 deskjet printer which also has a dongle installed. It pairs, but the printer driver...
Welcome to FixYa.
You have to configure the Bluetooth settings of the printer first. I assume that you have the HP bluetooth dongle on your printer.
Configure Bluetooth settings
You will need a USB cable to configure the Bluetooth settings
  • Connect a USB cable from your computer to the rear USB port on the printer.
  • Open the printer Toolbox.
  • Click the Configure Bluetooth Settings tab.
  • Configure the settings you want, and then click Apply
    Keep me posted.
Sep 09, 2011 | Computers & Internet
Printer setting is done for landscape then also it gives out potrait
Check if the software that you use, take information from the driver or the printer. If is from the driver, please check the configuration from the driver if is correct with the labels that you working. Possible the configuration is wrong on the printer.
Reset the printer to fac. defult, but first print the configuration label.
Oct 06, 2010 | Zebra Z4Mplus Label Printer
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Configuration setting does not save
make the changes on the printer,
save the changes (press twice on setup button).
chek if the driver have "use driver setings"
if you want to use the setings from the printer, you need to change the "use drivers setings" to "use printer setings ( this is to change on the driver)
Apr 10, 2008 | Zebra Z4M Printer
15 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
