Question about Chicago Pneumatic QRS15HPD-3 15HP 45CFM Quiet Rotary Screw Air Compressor with Air Dryer
I have a qrs-4000 compressor that trips the motor overload only once every morning at first start-up. then it never does it again until the next day.
    Novelist:
  • 214 Answers
I recommend you check the running amps at start up in the morning. Hopefully you will find the amps are over the overload rating. Check the amps again later in the day.Hopefully they will be below the overload rating. If this is the case you will need to go up on the amperage slightly to prevent the morning trip. Also make sure all incoming wiring are tight. Everything in the morning is cooler, not lubricated, cold oil etc. After warm up the motor doesn't have to work as hard and pulls less amps. Are you using a synthetic oil? If not synthetic oil along may be the answer to your problem.
Posted on Mar 21, 2011
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
Admiral HMG61139 21.1 cu ft Side-by side refrigerator, not cooling. clicking sound every few minutes. (sounds similar to oven thermostat or relay coming on).
Thier is one of a couple things going on with your refrig.
The start relay on the compressor is bad so what your hearing is the overload thermostat tripping on and off and keeps trying to start the compressor
The fan motor by the compressor called the condenser fan motor is not running to cool the compressor so once and what you overload keep trying to start the compressor but its too hot to start
Finally the compressor is locked up and the overload still keeps trying to start it but its totally seazed and ain't going to run
I hope this helps you to determine what is wrong with your refrigerator,
Gene
Aug 10, 2011 | Admiral 26 cu. ft. Side-By-Side...
The freezer stopped freezing, I hear a click every 30 seconds or so, I hear the blower blowing. I turned the dial to 3 and next day it froze again, but in the morning it had defrost again. I took the...
you need to replace the ptc overload/relay_is what is clicking) thats on the side of the black motor commonly known as the compressor,it merely unplugs off the compressor and an exact replacemant is available from most appliance dealers
May 16, 2011 | KitchenAid (KSRD22FKST) Side by Side...
WE HAVE AN ATLAS CAPCO GA 15FF MODEL AIR COMPRESSOR.IT HAS A PROBLEM THAT IT SHOWS THAT MOTOR OVERLOAD PROBLEM AND SHD NC HOW IT CAN B OVERCOME
We need to try to find the problem by doing a little trouble shooting. First check the amp rateing on the motor name plate. Next check the amp setting on the motor overload. It should be set no more than 10% above the motor rating. While checking the overload setting check all of the starter and overload lugs/screws to make sure they are tight.Next lets check the amps on the the motor using an amp meter with the motor running and compressor fully loaded. Amps at full load should be within 10% of name plate rating. If Amps are high Check incoming voltage. If all of the above checks out you may have something internally happening in the airend.
Nov 15, 2010 | ACCO Brands Air Tools & Compressors
Pump humms and barely turns. Fan blade caught wire caused huge spark. wire has been replaced.pump does not really seem to get going and trips safety after a minute of running.
hi there!
short circuited at start damage motor compressor
if you have a service center for motor compressor have checked this one, motor compressor has thermal overload protection mostly on single phase motor inside the motor,in the absence of overload protector the winding of motor on start and running maybe shor circuited.this should be rewind by motor rewinder.check the cost of motor rewind to a brand new motor.have choose n it.have a nice day fix my rate.
May 07, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
Compressor wont start
It is probably a failed run capacitor for the compressor. Without the capacitor, the motor can't even try to run, but it will draw extreamly high amperage until it trips the thermal overload (avarage trip time 5-10sec) after it has a few second for the safety to cool off, it will try again. Either that or the compressor truly is seized
Jun 22, 2008 | Coleman Mach III Air Conditioner
Chicago Pneumatic QRS15HPD-3 15HP 45CFM Quiet Rotary Screw Air Compressor with Air Dryer Logo
131 people viewed this question
Top Chicago Pneumatic Tools & Hardware - Others Experts
elunsford
Eric
Level 1 Expert
Are you a Chicago Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
