Question about Creative Labs Audio Players & Recorders
My speakers where runnin and immediatelty there is no power supplied to the speakers which in return not working now wat ll i do...?? is it a problem wid adapter or wat..??
  • Creative Labs Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 21, 2011
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
My speakers just out of the blue began to buzz in the middle of a song. The volume was low & did not seem to effect the buzzing - after I turned music off speakers began to make a high pitched ringing...
I've never worked on this model so I can't give you a definite part value or location, but you'll probably find a bad filter capacitor (or possibly more than one) in the power supply. The power supply converts the AC power line voltage to the DC (direct current) needed by the electronics. If the filter capcitors don't work, the result isn't smooth and steady, and the result is an annoying hum. You're probably hearing this.
It's possible to replace the bad capacitors, but it's not always easy. The people who make computer speakers don't often design them to be serviced, and sometimes it's a challenge getting into the power supply. But if you or someone you know with some electronic soldering skills is willing to give it a try, you might be able to bring these speakers back to normal. Good luck and thanks for using Fixya!
Jun 01, 2011 | Dell Ay410
The problem on my speakers are that it won't turn on and the light for the volume control won't turn on. can i fix it or do i have to buy a new one ? please contact a.s.a,p thank you
Id try to find another power supply to plug into them with the same voltage. Usually 9-12 volts. Walmart,radio shack, or kmart have universal power supplies you can purchase to test them. Maybe keep the receipt and return it on the chance that it still doesnt work(in which case you'll need a new set of speakers).
May 16, 2011 | Creative Labs Inspire T2900 Computer...
Hi my packard laptop GHA20 got no power wat will
defective connection on the motherboard....mybe.....or no voltage on your Power Supply, if you have a cat or dog or rabbit it might have eaten it , it will work only clear from were it bit, and the Power Supply will work again. ( it has a short curcit sensatity) new Image().src = "http://counter.yadro.ru/hit;gfeed?r" + escape(document.referrer) + ((typeof(screen)=="undefined")?"" : ";s"+screen.width+"*"+screen.height+"*" + (screen.colorDepth?screen.colorDepth:screen.pixelDepth)) + ";u"+escape(document.URL) + ";h"+escape(document.title.substring(0,80)) + ";" +Math.random(); var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www."); document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); try { var pageTracker = _gat._getTracker("UA-11118168-2"); pageTracker._trackPageview(); } catch(err) {} new Image().src = "http://counter.yadro.ru/hit;gfeed?r" + escape(document.referrer) + ((typeof(screen)=="undefined")?"" : ";s"+screen.width+"*"+screen.height+"*" + (screen.colorDepth?screen.colorDepth:screen.pixelDepth)) + ";u"+escape(document.URL) + ";h"+escape(document.title.substring(0,80)) + ";" +Math.random(); var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www."); document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E")); try { var pageTracker = _gat._getTracker("UA-11118168-2"); pageTracker._trackPageview(); } catch(err) {}
Jun 14, 2010 | Computers & Internet
Are PC power supplies generic?
According to Acer's website:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireM5100/AspireM5100sp2.shtml
The computer uses an industry standard 250W power supply so yes as long as you buy one that has all the connectors you need then you'll be fine.
May 14, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
MY Fender Passport P250 went into protect mode. I changed the FUSE at the power supply with a new fuse. Still it is in Protect mode. How to fix this
This needs to go to the repair shop. The protect mode is turned on when either the power supply has a problem or one or both power amplifiers have a problem. These are often blown components.
These units are HARD to work on. To open you have to first remove then front panel before you can remove the back panel that has the power supply and power amps/heat sinks.
Compare repairs of these units to working under an automobile dashboard!
Hint: On startup, use a series 150 wat lamp to limit current while repairing. SInce these use a switching supply operating off the input line, use an isolation transformer for personal safety.
Oct 04, 2009 | Fender Passport Deluxe 500watt Sound...
Does the power supply you purchased from LCD Payless still working?
I tried to purchase one for the $142.00 and it was not in stock. I think contaced the person someone recommended on this website. This was his answer:
It seems a lot of people are having problems with the Protron power supply. I’ve been able to repair all the ones I’ve seen so I’m confident I can fix them. I don’t sell the replacement power supply but I’ve heard about the ones on EBay. They seem to be a mishmash of two power supplies (12vdc and 24vdc) wired together with the proper connector. This should work but it just doesn’t sound very clean looking to me and they end up costing $150.
I’ve been charging between $50 and $100 to repair these power supplies. My recommendation would be to send me the power supply I’ll check it out and unless it’s unusually damaged it will cost $50 plus shipping to repair. If I can’t repair it I’ll return ship it and only charge for shipping.
I will guarantee the repair for 1 month. I don’t know what’s causing the power supplies to fail so I can’t guarantee it any longer than that. My feeling about the reason the Protron power supply stops working is two part; could be overheating due to lack of proper ventilation to the power supply; or the TVs power requirement is overdriving the power supply.
Feel free to contact me if you have any questions.
I repair these at my work, so here’s the shipping address:
Dave Simpson
23372 South Pointe Dr.
Ste. B
Laguna Hills, CA 92653
Also, I’m set up for PayPal.
dave@thola.com
Sep 05, 2008 | Protron PLTV-32 Television
Speakers not Working :(
The Problem might be that the speakers have an internal problem or that the wires are messed up inside. What I suggest you to do if you can is to return them to the store where you bought them.
If you need more instructions on how to try to fix the speakers, please feel free to contact me and I will Be GLAD to help you.
Thank You and have a good day!
Jun 18, 2008 | Creative Labs SBS 330 Computer Speakers
Dead Power Supply
Call 888-257-8899 $69.95 plus shipping
Feb 19, 2007 | Protron PLTV-32 Television
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
