Question about Maytag MZD2766GES Side by Side Refrigerator
I have a Maytag model MZD2766GE refrigerator/freezer I have noticed that around the edge of rthe refrigerator where the gasket is it is staying quite warm.....Is this normal?
    Master:
    Sergeant:
  • 385 Answers
Yes, this is normal. There is a heater that runs around the outside to keep it from sweating.Some models have a switch on the inside of the fresh food section so that you can turn off the heater.
Posted on Mar 21, 2011
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
MAYTAG MZD2766GE makes a loud buzzing noise coming from the top of the refrigerator side I think it is when the defrost cycle begins
OK I'm going to ask you some questions about your ice maker. No Problems? You said you noticed this sound around defrost time and have you ever had problems with defrost on this refrigerator before? The way it sounds from here is something related. So I will list them in order of most likely. That would be the adaptive defrost control part number Click Here=> 61005988 then the other two less likely are the defrost heater part number Click Here=> 61006199 When the ADC begins to go bad strange things may happen, The compressor and fans are surposed to shut off and then the defrost heater comes on. Afte defrost begins to reach 50 degrees inside back wall of freezer the defrost thermostat opens to keep the defrost heater from remaining on and defrosting the complete freezer. This for me is a guess and go situation because I am not there to see and hear what you do. So to insure we both are well informed I will leave you with a Service Manual Click Here=> MZD2766GE Your manual covers several models and on page 42 shows a defrost timer and that would be less likely to create strange sounds. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
a0d03ed.jpg5e9645a.jpg Defrost Heater Assembly used on some Maytag brands appliances. Include defrost thermostat.
Mar 15, 2010 | Maytag MZD2766GES Side by Side...
My referigerator is running coolabout 45 degrees.freezer/wmer sometimes. thefreezer is not gttig real cold. hope you can give a idea of what may be wrong
You may have a sealing issue with the freezer door. If the rubber gasket around the edge of the freezer door is not sealing properly it will cause the freezer to be warmer. You may not easily notice the seal problem so check it all around the four edges of the freezer. hope this helps :)
Dec 12, 2009 | Whirlpool Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Where is drain hole on maytag MZD2766GE side by side refrigerator
in the freezer at the bottom can be seen by removing back panel hot water will open it up if not blow through with small hose
Apr 17, 2009 | Maytag MZD2766GES Side by Side...
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
No water coming from dispenser on Maytag MZD2766GE
You should defrost the freezer. The water line coming into the freezer is frozen and the water can't get through the little tubing.
Feb 01, 2009 | Maytag MZD2766GES Side by Side...
Maytag
on some Maytags if the defrost thermostat in the freezer gets above its setting (around 50 degrees) the fans won't run. It shouldn't be like that very long...10 minutes tops then they'll come on all by themselves.
Dec 28, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
119 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
