Question about Linksys Wireless-G Broadband Router
When I power up my router I get 5 lights , nothing for a power light . Should there be a light on for that ? How many lights should be on total ?
  • 1,591 Answers
It sounds like a bad flash attempt has bricked the unit (made it as useful as a brick)
It can be revived, but you need a copy of the original firmware and a piece of hardware called a JTAG to flash the nvram in the unit and revive it.
If you google linksys jtag ebay you can usually find this hardware for under $10.
Some computer stores will also do this for you for a nominal fee.
Here's a great little video of the process.
Best of luck!
Posted on Mar 21, 2011
  • Norman Skinner
    Norman Skinner Mar 22, 2011
    There is also a chance your power adapter is failing, check the voltage with a meter.
  • Norman Skinner
    when the router is working right (to answer your other question) the power light, WAN light and possibly the wireless light should be on (assuming the modem is on and hooked up to it)
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
Haw can i install Belkin wireless router N300 without the CD
You can easily follow the following steps to install it without a setup CD
Step 1: Please find a compatible power source and plug your modem into it.
Step 2: Now, you can connect your computer to the modem using an Ethernet cable without the router being installed.
Step 3: please verify whether your computer is receiving an internet connection or not. Just click and access any website of your choice.
For more details kindly visit How to Login Netgear Wireless Router Routerlogin net
Apr 10, 2012 | Belkin F5D7234-4 Router
D-link514 wont turn on after storm power outage
The cause is the power-supply "brick" to the DI-514.
It has failed.
So, it's time to buy a "surge-suppressor" (sometimes integrated into a high-end power-bar) and to buy a new router, for less than $80, in total, to be protected and be ready for the "next" storm.
Jul 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
D-Link DIR-615 (wireless router) no power light on ???
If the power pack is good then the router is dead and needs to be replaced. It's generally cheaper than trying to fix it.
Dec 12, 2009 | D-Link DIR-615 Wireless Router
I seem to have totally lost power to my router. No lights noise nada. It doesn't seem to power up and i have no wireless signal.
Try unplugging the router and holding down the RESET button in the back of the router down for 10 seconds...then try to power it back on. Can you also try plugging the power supply into another socket?
If nothing changes then either the power supply went out or the router itself just died.
Most are covered for a year so hopefully you kept the receipt.
Nov 29, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Sep 11, 2009 | Televison & Video
Router is not working
What does this line mean? "It's reading all the other computers but isn't working."
Do you mean that the other computers are hard-wired to ports 1, 2, 3 & four on the back of the router? Or are you going totally wireless? Is your cable, or satellite modem plugged into the port labeled WAN?
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable from your modem and plug it into the WAN port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem and wait for it to go through its boot cycle. It takes about 30 seconds. Watch the lights on the modem to tell when it has finished booting.
6. Plug the power adapter into your router. Again, wait about 30 seconds for the router to boot.
7. Turn on your computer.
8. Verify the link lights on the router. The power light, WAN light, and the LAN light for the port you plugged your computer into.
Now, open Internet Explorer (web browser) and in the Address line, type 192.168.0.1 and hit enter. You should see a login screen. Enter a user ID of admin and leave the password blank.
This should log you into the configuration utility for your router. You should see a Setup Wizard button that will walk you through setting up your router.
Mar 02, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Lights not lit on router??!! Brand new!
as long as you have connected your powered up modem to the rear port of the router and set it up firstly through the RJ45 cable and it is plugged in, then the power light should be on, if no power light then nothing is going to set up, so as long as you know you have followed the instructions, it must be a faulty unit, but go through everything again, as you may have missed something; as we all do at times.
Jun 15, 2007 | Linksys A+G WRT55AG Wireless Router
Linksys Wireless-G Broadband Router Logo
140 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
