Hi, My motherboard is MSI 945GCM5-F V2 AND I have bought MSI R5450MD512H vga card in order to upgrade my graphic performance but it wouldn't start and can't be seen under windows. I have set the primary VGA to PCI-E. The card works fine in another computer and another PCI_E VGA card works ok with the motherboard. I have upgaraded BIOS to the latest version aveilable from MSI site (Windows update didn't work (tried wit Windows XP SP2 32bit and Windows 7 64bit)???, but have done it with DOS diskette. I have read somewhere that you have sent someone unofficial version of bios for the same graphic card and that problem was solved that way. Please advise. With best regards, Djordje Dimitrijevic
ginko
  • 19396 Answers
SOURCE: Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Posted on Apr 03, 2008
proton77
  • 1183 Answers
SOURCE: Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Posted on Aug 28, 2009
Testimonial: "I thought I had tried everything, but Proton taught me something new, and only a minute or two after I posted my problem! Works great now. Thanks!"
  • 103 Answers
SOURCE: Problem With Nvidia 8400 SE Graphics card
Try reflow technique.
It could work.
Its might be a GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
Clarifications:
gnaveendra@gmail.com
Posted on Jun 05, 2010
  • 5 Answers
SOURCE: MSI G31TMP21 Motherboard: VGA has
Start windows 7 in safe mode and reinstall the drivers for your graphics card.
Posted on Mar 05, 2011
  • 525 Answers
SOURCE: I've a MSI motherboard ms-7399
Bad power supply.
Posted on Mar 19, 2011
I have msi 945gcms v2 motherboard & i do not find its vga drivrer for it
Download here at MSI:
http://www.msi.com/product/mb/945GCM5.html#/?div=Driver&os=XP%2032
Select your windows system
Download your driver and unzip before you install.
Good luck
Sep 17, 2011 | MSI 945GCM5 Motherboard
Is the MSI 945GCM5-F 7.1 motherboard on-board graphic card compatible with LG Flatron wide screen? Up until now we had a GF card, but now it's gone, and using only the MSI we don't seem to be...
Hi
You don't say how big the screen is, what connectors it has [VGA (Analogue), DVI (Digital) or HD (High Definition)] or which Operating System you're using.
Right click on open space on your desktop.
Properties > Settings (XP)
or
Personalize > Settings (Vista, Win 7)
Left click & hold on the slider and slide to adjust resolution.
You are given the option to test and accept each setting change you make.
When satisfied, Apply > Yes > Ok. Then restart the computer.
If your screen is large and has Digital and/or HD capability and the above advice does not help you find a resolution setting thast completely satisfies you, you may need to consider a dedicated PCI-Express Graphics Card to upgrade your graphics performance and give you a wider range of resolution options.
Hope this helps.
Aug 23, 2011 | MSI 945GCM5 Motherboard
I got a PCIe Graphic card but apparently even after i have fitted it perfectly into the slot, the display won't switch to the graphic card from the onboard video.please help.
You will go to BIOS SETUP and press F2/F10/ Dell
Disable on Bord VGA or set the graphics piority
http://www.pcbuyerbeware.co.uk/BIOS.htm
FOR VGA
http://www.pcbuyerbeware.co.uk/AGP.htm
1st pci slot
2nd on-board VGA.
Follow link
It will help you.
Regards
Shibuda
Jan 05, 2011 | MSI 945GCM5 Motherboard
NO VGA DRIVER IN MY WINDOW AND NO AUDIO DRIVER'S
Click here to go to the MSI Support Download Center.
You can download Audio, LAN and VGA drivers here.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 03, 2010 | MSI 945GZM3-L (7267-020(945GZM3-L))...
I have The Msi 945gcm5 V2 ,i unable to get display
you will have to start at this link,i dont know the details about your board,use the manual download on the right side of the page,fill in the dropdown boxes with the details about your board and you should get to your drivers hope this helps,if you have trouble post a comment an ill try to get back and help aloha todd0708
http://www.msi.com/index.php?func=downloadindex
Oct 05, 2009 | MSI 945GCM5 Motherboard
I need ms-7267 ver 4.2 drivers
I want to download driver mother board ms-7267 ver:4.2
Jun 07, 2009 | Intel Motherboard
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
