Question about LG Televison & Video
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • LG Expert
  • 177 Answers
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Posted on Mar 21, 2011
  • 22 Answers
This model of the TV only has an HDMI input. So, you can only use HDMI to connect your computer to your TV.
Connection to PC
I have had the same problem. If you have a VGA cable shown at the bottom. You can hook that into your laptop into the TV. The slots look like a blue incovering. You can also look at the image below that one for more additional help....
images?q=tbn:and9gcsiv-gyi4jh5l6apvblrydzbiwzndoskvj3ytpifllclwa1qmks
images?q=tbn:and9gctjzjmvlnbu_yfg04yh87cl2mau36aexgpvkl7rwz0yczn0azmwaq
Jan 29, 2014 | LG RZ23LZ55 23 in. LCD Television
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
Can you use an xbox arcade on flatron LG L1810T? If so which setting does it have to be on as the tv is not recognising the xbox at all
HI,
Your LG LCD monitor has a white DVI connector for connecting the signal cable.
You would reqire either an HDMI to DVI(male connector cable for the xbox) so that you can hook the hdmi cable to the xbox and other end to your monitor.
The cable would look something like this
http://hardware.teamxbox.com/reviews/xbox-360/40/Xbox-360-VGA-HD-AV-Cable/p1/
Thanks
proton
Jun 06, 2010 | LG Flatron L1810T 18.1" LCD Monitor
Where do I get a cable to connect my laptop pc to the DVI input jack on the Soyo 32" LCD TV?
You will need either a DVI-I to DVI-I cable or a DVI-I to HDMI cable. Your computer should have a DVI-I output or HDMI. You can not directly connect a VGA output to the TV. If needed, you can purchase a VGA to component (Y/Pb/Pr) converter.
Mar 15, 2010 | Soyo DYLT032C 32 in. LCD Television
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
Acer aspire 3610 can i use my laptop to connect to lcd tv i have vga output
So if there is not a vga input connection on your lcd tv which most do. You can get a vga to dvi cable adapter in conjunction with a dvi to hdmi conversion cable. Note that you may have to change your resolution settings in order to veiw computer images on your lcd t.v. If your laptop has an svideo output you can also connect this way but the image quality will be greatly reduced.
Dec 10, 2008 | Acer Computers & Internet
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Televison & Video Logo
1,500 people viewed this question
