Question about Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302
My water heater makes hoise what can i do to make it quiter
You posted under electric water heater.
1) Gas or electric, the noise is from sediment build-up inside tank.
Once sediment builds up, the only way to solve problem is to clean the tank out.
2) To restore full efficiency to electric water heater and stop the noise, clean the tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
3) To clean gas water heater is more difficult and less successful:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) To prevent sediment problem, flush water heater each 6 months before sediment can build up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
5) Other things to know for water heater maintenance.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Posted on Mar 22, 2011
How do I just the water heater to make the water hotter
To make the water hotter, u may constrict the water flow that goes through the tap, shower etc. With the water flows slowly, the heater has more time to heat the water in it and then the water will be hotter although it won't be boiling hot(100 degrees Celcius) because the water heater is not designated to heat water up to that temperature
Apr 09, 2013 | Water Heaters
Manual for wards hot water heater
1) Copy following links to identify gas control valve, troubleshoot resources, and gas water heater installation
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Unsure which manufacture makes/made Wards water heater, or how old your unit is.
Three manufactures make most brands tank-type water heaters, and generic manual basically covers all brands.
http://waterheatertimer.org/Water-heater-manufacturers.html
3) Add comment Feb 2013, and say what you are doing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 03, 2013 | Water Heaters
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
I want to buy a new energy star 50 gal. gas tank hot water heater that will be trouble free (not like the PROMAX GVC) can you give me some suggestions on makes and models that are reliable, energy friendly...
Hi Chris.
My experience with water heater is like cars.
There are a few manufacturers making all the cars, and people sometimes get a bad one.
AO Smith, Bradford White, Rheem make most of the water heaters.
Each is shipping 150,000+ water heaters a month.
Since all costs are energy, I suggest buying off-the-shelf tank-type water heater at local box store.
Sears, Ace, Home Depot, Lowes/ in no particular order.
The big manufacturers make box-store brands. All brands are good. The warranties are industry standard.
Stay away from blowers and electronics so you can maintain and repair the unit yourself with common, inexpensive off-the-shelf parts.
Install it yourself for around $330.
Adapt to the water heater. Read the manual and advisories. Do the maintenance so you are not disappointed.
Use the old tank as a staging tank for cold incoming water, or use it for DIY solar water heater:
Read the money-saving installation tips, plus a few maintenance tricks shown on following link.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 14, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
HOW LONG DOES IT TAKE AFTER INSTULATION TO HEAT WATER
Electric water heater typically makes 21 gallons hot water per hour.
Gas heater makes 41 gallons per hour.
If you use a timer on electric heater, it will make enough hot water for shower in about 15 minutes summertimer and 30 minutes wintertime. So incoming water temperature is a factor.
If your water heater is not full of water before turning on electricity, then elements will burn out.
Also the ECO might be tripped out: open top cover and push in red reset button.
How to troubleshoot electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Apr 18, 2011 | RELIANCE ELECTRIC WATER HEATER
No hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Sep 22, 2010 | RELIANCE ELECTRIC WATER HEATER
My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Jul 29, 2009 | RELIANCE ELECTRIC WATER HEATER
Rheem 30 GAL ELEC SHORT Water Heater 6YR SC 82SV302 Logo
196 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
