Question about Miele CVA615 Espresso Machine
Watersystem fault - Miele CVA615 Espresso Machine
    Genius:
  • 1,157 Answers
Hi bird_gl,
Most often Water system fault occurs when the water tank is not seated properly allowing water to drain out of the tank and into the base.You can easily fix this by following the steps below.
1. Please remove the water tank.
2. There is an access opening like a round hole in the base beneath were the tank fits into the machine.
3. Using an absorbent cloth material dry the water through this opening. Please be patient, it can take sometime.
4. Once the water is gone the machine will operate normally again.
You are encountering "Water system fault" because water has seeped into the pan beneath the coffee maker. There are alignment pins on the tank that fit into holes in the coffee machine. Make sure this alignment holes are clear of any debris. Coffee beans have been known to make their way into these openings. Please use a flashlight and a small mirror to see down into the alignment holes.
Hope it helps.
Thank you for using FixYa.
Posted on May 11, 2011
Manuel on 1996 terry travel trailer hot water tank
Request directly from Terry.
Mar 09, 2018 | RVs
Miele 4070 watersystem fault but the catch tray has no water so it's not overflowing. What might this be?
it is leaking internally. When the drip tray is full, it tells you to empty the drip tray. when the machine has a problem and develops a leak, it locks up and displays watersystem fault. contact miele at 800 843 7231 and they can put you in contact with a service center in your area.
May 25, 2011 | Miele CVA4070 Coffee Maker
Watersystem fault
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Miele CVA610
Miele coffee machine shows"watersystem fault"
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
Aug 29, 2009 | Miele CVA4070 Coffee Maker
Watersystem fault. Anchorage, Alaska
I've just had my machine fixed by a miele technician. Turns out the rubber beneath the water reservoir had worn out after 5 years. Because it was leaking, the machine was filling up with water. It protects itself by giving you the message. You can remove the reservoir, take a flexible tube/hose and drain the machine. It will probably fix the problem for a while. The Miele part number for the rubberseal is 05046331. Pretty cheap.
Jul 29, 2009 | Miele CVA615 Espresso Machine
Watersystem fault
This is a design flaw of the Miele CVA610 and CVA615. If the water reservoir is not properly installed, it will leak into the sump. The only solution is to have a turkey baster on hand for this invevitable situation. This has been confirmed to me by both a Miele technician and their technical support people.
Apr 18, 2008 | Miele CVA615 Espresso Machine
Watersystem fault
Thanks for the solution . I fixed my "Watersystem fault" . The wet switch in the unit is activated when water gets into the base of the machine to prevent water damage to the cabinetry .
Sep 08, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
296 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
