Question about Fujitsu Plasmavision 42" TV
TV won't turn back on after power cord was disconnected from unit
TV was installed and connected to other components, and worked fine. Power cord became unplugged from unit and now TV will not turn back on.
    Sergeant:
  • 308 Answers
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Posted on Aug 03, 2008
Why does my tv shuts off soon after its turned on?
The Sceptre is a fine TV but is very sensitive to power surges.
If the unit turns off, soon after powering on, it is most likely the power supply.
Try disconnecting the power to the unit for 20 minutes and allow to completely cool down.
Re-connect the power and try the unit.
Hope it works for you
May 23, 2014 | Sceptre 32 X320BVHD 32 LCD TV
Digix bd 500. worked fine for a couple Weeks. now it froze up and won't turn on. the power lite is dimly blinking. but still won't turn on. is there a way to reset without turning on? I have check...
1) test the outlet wall for 120vac 2) test the power cord for open 3) test the power switch tv for defective 4) power supply inside faulty repair.
God bless you
Jul 25, 2013 | Televison & Video
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
I have a 1992 mecrury sabe sw that i'm trying to put a new head unit in. i took the stock radio out and disconnected the wires and power cord but now the new head unit won't turn on, the stock...
check here and make sure that you have power coming into the harness, if not back track it to the fuse http://www.installdr.com/Harnesses/Ford-Wiring.asp you want to look at this one Standard 2 Piece Harness Up To Late 1990's
Jul 19, 2011 | 1997 Mercury Sable
My philips HTS 3555 stopped working. The standby light comes on sometimes but when I push the button, It turns green, the fan turns on for a second, then off, then on for a second, then off again. It then...
Your unit being stuck in standby mode is an indication that its having a power problem. Remove it's plug from the wall, wait for about 30mis, fix it back into the wall, then turn it on again. If its still stuck in standby mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Apr 21, 2011 | Audio Players & Recorders
Touch screen wont work
Try the following to bring the touch screen backto life.
Step 1:
Do a power flee by unplugging the power cord from the rear of the printer and holding down the power button for 30 seconds.
If the above doesn't resolve the concern, then try the step 2.
Step 2:
Perform a Full Reset of the HP Photosmart ,
-Press the On button to turn off the unit.
-Disconnect the power cord from the back of the unit.
-Disconnect the power cord from the AC outlet.
-Connect the power cord to the back of the unit.
-Connect the power cord to the AC outlet.
-Press the On button to turn on the unit.
If the touch screen has not gone bad,the above troubleshooting steps should resolve the issue.
Thanks and regards,
Techbuddy247
Jun 10, 2010 | HP Photosmart D7260 Printer
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
Sony 46" lcd turns off by itself and will not power up again.
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
Fujitsu Plasmavision 42" TV Logo
99 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
