Question about Whirlpool Washing Machines
Refuse to make automatic drain - Whirlpool Washing Machines
    Brigadier General:
  • 6,277 Answers
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 21, 2011
Mazda cx-5 i-stop not work on at night when i driving with headlight on?
Autostart/stop is dependent on battery voltage above all else. If the system senses battery lower than perfect charge, it disables automatically the prevent battery from draining due to frequent restarts with inadequate charge time (especially in stopand go traffic). When your headlamps are on, you typically have an extra drain of 12-30 amps, and more on some cars with HID headlamps and multibulb driving lamps. The alternator knows these cars will draw so much (over 30 amps) if left on for a 2 or 3 minute stoplight wait, the battery may get drained to below optimal...so the system will frequently refuse to activate when headlamps are on. On cars that are voltage sensing only, or have date coding/mileage coding of the battery (BMW mainly), a new battery will re-enable the night use on such a system. On cars where it is sensing load, you may have to accept that you cant use the system at night.
Jan 04, 2018 | Mazda Cars & Trucks
Wont drain in automatic cycles
maybe is necesary to set the drain operation in the automatic cycle,like you can set the temperature of the wather ,the time to prewashing and so on.
Dec 26, 2013 | Whirlpool Washing Machines
W3831 not draining
check the drain hose is not clogged, also check the pipework that the drain hose goes into. if there is a block the machine is programmed to stop pumping.
Dec 12, 2013 | Miele Novotronic W1918A Front Load Washer
Dust board light showing T/A oil temperature, and the engine is not starting, what could be the problem?
That lamp usually lights when the automatic transmission fluid is overheated, which would correspond with being stuck in a traffic jam.
this would happen very quickly if you had the vehicle in drive with your foot on the brake while inching forward in very hot weather.
The engine may refuse to restart until the fluid had cooled somewhat.
It also indicates that it is time to drain and refill the auto as the fluid has been subjected to excess heat which degrades the fluid and can increase wear rapidly.
did the vehicle restart when the fluid had cooled?
Jan 19, 2013 | Nissan Terrano Cars & Trucks
I cannot find my pump filter on my front loader washer.
mine is front right hand side underneath the washing machine
Feb 12, 2012 | Frigidaire Washing Machines
I have a 91 honda accord with an automatic trans. & when i shift into reverse it refuses to engage & makes a high pitch gear slipping grinding sound ! NOT GOOD ! ,I just replaced the transmission con
Definitely not good. The transmission is slipping internally due to worn gears and clutch packs. It will have to come out for rebuilding, IMO. Have a transmission shop check it out.
Good luck.
Dec 23, 2011 | 1991 Honda Accord
I live in a modular home. My tub drain isn't a
There is no nut but the drain piece is threaded. Carefully cut out strainer with a jab hack saw.
Sep 24, 2009 | Moen Accessories 90522 Chrome Tub Drain...
Dishwasher will not empty
check to make sure nothing is binding the impeller, ie: broken glass, coins, twist ties, plastic bag.
Jan 18, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
13 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
