Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
  • Whirlpool Master
  • 3,740 Answers
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Posted on Mar 21, 2011
Whirlpool Cabrio won't drain or only intermittently with LD code
Sound like there were threads wrapped around the impeller shaft inside the pump. Matter of fact I just replaced a pump for a client cause a nickel had gotten inside the pump and got between the impeller and outer casing. The nickel punched a hole in the housing of the pump therefore causing a leak. Couldn't get just the housing. Had to get the whole pump.
But it sound like the drain pump is under a lot of strain and probably needs to be replaced. Strain from threads around the impeller shaft or something else. So the pump motor gets hot from stress and strain causing the coil to heat up and short out causing an electrical smell. I found used pumps very reasonable for this unit on ebay.
Apr 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool refrigerator model # ET1PHKXPQ00 ser# ER2137141, Type 21TFA, dated 05/2004. It runs fine, but I am getting water in the bottom of the refrigerator all the time now. A...
  • you need to remove the cover where the fan is mounted and you will see ice build up there is the hole but you may need to use hot water to clear the ice and clear the drain hole water should come out to the back of the refrigerator you need to remve the cover behind to see the drain line make sure to disconnect the unit before you work on it.
Mar 17, 2011 | Whirlpool Refrigerators
Leaking water into crisper. Water is freezing in freezer pan. Model 21TFA.
i would say you have a pluged drain tube from the top locted behind the freezer rear panel.
Nov 27, 2010 | Whirlpool Refrigerators
My whirlpool refrigerator 21TFA is leaking water from freezer into fridge. This model does not have an ice maker.
The drain is clogged. Remove freezer plate and pour a mixture of baking soda and warm water down drain.
Nov 02, 2010 | Whirlpool Refrigerators
Whirlpool refridgerator leaks water from freezer into refridgerator
Need to check the defrost drain for clogs. Empty the freezer and pull the panel in the back. Use a turkey baster to the drain hole to see if that will clear it. If there is a clog, insert a wire down the drain hole to force the clog down the drain pan.
Aug 27, 2010 | Whirlpool Refrigerators
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
434 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
