Simpson washer model swt605sa shows E6 please let me know whats this mean Thank you Don
    Brigadier General:
  • 6,277 Answers
(try this just in case!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 21, 2011
Hw do i reset machine settings on a simpson encore 816
Don;t understand what you mean. A bit more info on what the problem is and why you think there is a way to reset it would help.
Jul 31, 2016 | Simpson Washing Machines
I getting a F7 E6 error code, What does this mean and how do I fix it?
What kind of washer? I'm finding "Stuck Keypad - Unplug and Plug Back in", "Motor not Reaching Target RPM" and a couple of others that I can't remember, On different washers there are different meanings Google "F7 E6 error code, What does this mean and how do I fix it?" and you should come up with the same answers I did.
Jul 03, 2015 | Washing Machines
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I am getting an "E6" on my motor when I turn it on. Do not know what that means and I do not hear the motor running.
Hi Nancie
have a good day to you
can you please tell me what kind of control model ? any way E6 coming with control model ( SC-1 / SC-380 / SC-2 ) it means:
-Check the control panel cord for
disconnection. (Check whether
the panel cord comes in contact
with the V belt.)
-Check whether the control panel
connectorhas loosened, (Check
whether the control panel connector
has been securely connected
to the machine.)
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Jan 18, 2015 | Juki DDL-8700
What does E6 mean on a baumatic bwm70
E6 on the bwm70 means that there is a water sensor level error. You can try resetting the error code to see if it comes back on by pressing and holding the the power on, start/stop button, or unplug the washer, wait 30 seconds and try again. If you still get the E6 code, your washer will need to be serviced
Jun 18, 2014 | Washing Machines
Towa ax 100 E6 error
What does E6 code on Towa AX100 mean?
Sep 13, 2013 | Casio Parts Cash Register PC Desktop
New Simpson Top loader washer very noisy/rocking
sounds like you havent undone the transit bolts- theyre on the back of the machine, 2,3 4 maybe five quite large obvious bolts, around the drum but on the back. they are to keep the drum steady while in transit to stop the machine bouncing around in the van - you are unlikely to have damaged it - Undo these bolts - they should be mentioned in the manual-
Jan 20, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
