Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remotes don't work
Both of our garage door openers stopped working at the same time...sort of. If I hold an opener close to the antennea it will operate the garage door, however it will not work more than five feet away and doesn't work at all outside the garage. We've replaced both batteries in the remotes with no success. We have a Craftsman 1/2 horsepower Model # 139.53664SRT2. Hope you can help.
  • 8 more comments
  • kimburrlee Aug 03, 2008
    both our remotes stopped working at the same time. changed batteries still don't work. but the keyless entry pad works fine. what's going on?
  • kbl1 Aug 07, 2008
    I have exactly the same problem with my Liftmaster garage door opener. Until a few days ago, both remotes worked fine. I've installed new batteries and erased the codes and reprogramed the remotes several times, to no avail. Unless there is some kind of electrical interference that is affecting so many of these openers all at once, I am completely at a loss as to what is causing this. I'm wondering if the receiver/logic board in the opener unit might be the problem, but I do not know how to diagnose that. Any ideas or help from anyone out there would be greatly appreciated! Thanks!
  • Mustang6t7 Aug 08, 2008
    sears garage door opener motor works fine remote's won't work unit
    any ideas
  • pkfinanger Aug 14, 2008
    Both remotes do not work. The button inside the garage opens and closes the door just fine. The light blinks twice when I push either remote.
    Any suggestions?
  • Anonymous Sep 29, 2008
    okay this is freaky-my remotes stopped working also? only wall panel works-pain in the **** to walk into garage to get doors to open and closed..
  • Anonymous Oct 05, 2008
    This same problem started (for me) 10/3/08. Remotes only work within 5 ft of opener. Keyless does not work unless within 5 ft.
  • balata11 Oct 21, 2008
    My wife and I have been having the same problem all year. Our remotes will only work a few feet from the garage door or inside. A few weeks later, they work all the way from the street. The problem started again this weekend.
    I have been researching RF interference; but haven't found anything solid yet. It is the only thing that make any sense.
  • rufflife Jan 03, 2009
    All remotes (3) and both cars have instantly stopped working.  Nothing new in our garage or house to effect.  Any ideas?
  • bluesky668 Mar 21, 2009
    I have the same problem. All my remotes stop working all in a sudden. After reset the opener, the remotes will only work a feet away from the opener. If you have a solution, please post on this site. Thanks
  • bmbusa Mar 22, 2009
    I have a Sears Craftsman Garage Door Opener, Model# 139.53985D. Two months ago , both remotes stopped working unless you are about 5 ft. away. Replaced both batteries and tried reprogramming both remotes, did not correct problem. I suspect it is a receiver problem in the circuit board, but not sure how to diagnose it properly, any insight or help would be greatly appreciated.
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Posted on Aug 08, 2008
    New Friend:
I had the same problem and confirmed that turning off the FIOS ONT made the garage door opener work again. I came up with a low-tech, low-cost solution: get a cardboard box that's big enough to COMPLETELY cover the ONT; cover it inside and out with tin foil; ground the foil to a nearby outlet or other ground. My garage door opener now works as before from 30' or more away...Remotes don't work - 735c992c-5ccf-44a7-984c-5fe2dbd52d7e.jpg
Posted on Dec 01, 2013
All three of my garage door openers died on the same day. Only the wall pad works. Nothing has changed in the garage so I suppose it's the planned obsolescence of the remote. Guess buying a couple new ones is the answer. Good luck folks.
Posted on Oct 07, 2008
Hello everyone. I was having the same problem. I taped the antenna in place so it was in view of my car whenever I pull into the garage. My antenna wire is purple. It worked for me!!
Posted on Sep 21, 2008
How to fix my garage door opener?
I'm assuming you mean that it won't close, only open? If that's the case then your eye beams may need to be adjusted. The wall button can override the sensors whereas the remotes can not.
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Sears garage door opener wall switch works properly (I do NOT have to hold button in to close door), remotes don't work. Sensors are solid green and door reverses when beam is broken when activate
If you recently changed the light bulb in the unit, try changing it back to a basic clear bulb. I just had the same problem, and after research, found that changing bulb to a new type LED bulb messed up the remotes. A good test, is to try the remotes when the garage door light is "OFF". My remotes worked as long as the light was "OFF". I changed the bulb back to basic bulb, and everything works fine!!
Mar 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Our remotes (2 for the car and a keyless entry) stopped working. We erased everything (and checked to make sure our remotes weren't working) and reprogrammed all remotes. They work, but our neighbor's...
Make sure your neighbor doesn't have a remote with a sticking switch. Often times a person will stick an extra remote in a drawer and then place something on it that holds the button down. Try programming your remotes this way just in case you didn't.
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Sometimes it can help if you are in the garage when you program your remotes this way and it will drown out any distant signal.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Older model 1/3 hp craftsman goes up not down with remote
Your door sensors are either bad or need simply to be aligned. They must be pointed at one another to work properly. Each of them has a small light that will be lit when they are pointed correctly.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,414 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
