Question about Samsung ML 1610 Laser Printer
Printer getting stuck after the paper is half way through
    Genius:
  • 1,570 Answers
Hi
The printer driver is corrupted, either you set up again the printer once more by adding new printer with the same name and set is as default pirnter.
Or uninstall and reinstall and printer driver and set it up again to correct the corrupted driver.
Regards
Posted on Mar 21, 2011
THE PAPER GETS STUCK HALF WAY THRU PAPER FEEDER AND COPIES COME OUT DISTORTED VERY FRUSTRTATING WHAT CAN BE DONE IT IS NOT THE TYPE OF PAPER EITHER
There must be something stuck in the paper path, a staple pin or paper clips are very common to get stuck in ADF.. Try to locate the stop position check the area for any obstruction
Aug 15, 2013 | Savin 8035e Copier
Ok my Epson stylus NX110 isnt working like it was yesterday now the paper gets stuck half ways i mean i can hear the printer still running and all but the paper doesnt roll down???? what should i do???
  • Turn the printer off.
  • Please inspect the paper paths and look for any stuck papers which may cause paper jams.
  • Look through the feeding tray and remove manually any visible stuck papers.
  • Turn the printer on and print.
Hope this helps.Thanks!
Sep 29, 2011 | Epson Office Equipment & Supplies
STARTS PRINTING AND PAPER GETS STUCK HALF WAY THROUGH. THE PRINTER IS ONLY 3MONTH OLD, HOW DO I FIX THIS.
I need to know where the paper gets stuck and does it concertina ( fold up ).
Where is the leading edge of the paper when the paper stops feeding?
Jun 13, 2011 | Lexmark E260dn Laser Printer
Why does my printer stop printing half way through? It is like the paper gets stuck half way and it just sits there.
I don't know what is the model of your printer but first you have to clean the pickup roller, because the paper sheet is getting late and the printer just stops printing. Other reason must be the damaged paper sensor (maybe in fusing section) and it has to be replaced.
First try with cleaning ...and clean it well!!!
good luck
pifonski
Mar 02, 2011 | Office Equipment & Supplies
Paper Jam Toshiba 250
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks! mannu_rakesh
Aug 31, 2009 | Office Equipment & Supplies
Paper Jam / Printer Dock Series 3
try this no promises
unplug the power cord for 5 sec
paper should feed out after resetting
DONT EVER PULL ON THE PAGE WITHOUT THE MACHINE EXITING IT FIRST. THE TABS ON THE END OF THE PAPER BREAKS OFF INSIDE THE PRINTER DOCK.
check the back of the dock for the photo to eject as well as the front.
check paper size with new one after it exits to make sure no extra pieces are stuck in printer. good luck
DONT PULL ON PAGE JAM (UNPLUG FIRST(RESETS THE PAGE OUT THE BACK/FRONT))
Mar 13, 2009 | Kodak EasyShare Printer Dock Series 3
Paper Jam in a HP 7210
there is a door at the back of the printer , open the door and remove the paper
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Samsung ML 1610 Laser Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
