Question about Refrigerators
Where can i find serial number for my fridge ? hotpoint rf187b.
  • 122 Answers
It should be on the same label as your model number. Could be along side crisper inside or on the bottom under the kick plate/grille.
Posted on Mar 21, 2011
Need to know the year of a Hotpoint fridge. Ref numbers are: CTHY16EPERWH MF 780907
According to that model and serial number is was made in July 1991
Aug 24, 2011 | Hotpoint Refrigerators
Cant change temperature in fridge
you have to send the full model number off of the fridge,open the fridge door,look up near the ceiling on the left or right hand wall depending on your model and you'll see a tag with the model and serial numbers,just send the model number,g.e. makes hotpoint machines so most likely you have a bad computer board or mother board same thing,,usually it takes a wr55x10942 and it's around 150 to 200 hundred dollars but need the model number to check it,some take a different board but this is the common board.you'll find the board located on the back outside wall of the fridge,pull it out away from the wall,remove the screws and cover but first unplug the machine before you touch the board or remove the cover,there are 4 plastic clips holding the board in place,i use a needlenose plyers to pinch the clips and slide the bord out one at a time and then you can look at the back of the board to see if it has any burn marks on it,everything runs through the board and g.e. has had problems with the boards.don't order this board until you make sure this is the part for your machine by checking it with the model number .good luck.
Jul 05, 2011 | Hotpoint HMT40 Stainless Steel Bottom...
I have Hotpoint bought in 1990 and still works well. I would like to update the look, though. Can I buy new doors?
You have to call a hotpoit parts supplier to see if they still have them or if they can order the doors .They will ask you for the model and serial number wich is located on the side wall inside the refrigerator , some models you find these numbers at the bottom front on the outside of the fridge or also in the back outside of the fridge.
Jul 31, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge freezer has stopped working
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 01, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezes everything!
The defrost timer has failed. It is defrosting too long.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 05, 2009 | Washing Machines
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Future ffa90 fridge freezer
yes first are you in usa second get your correct serial number off the serial plate then go here http://www.geappliances.com/service_and_support/
Feb 18, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
