Question about HP Office Equipment & Supplies
We have a Laserjet P2050dn that is experiencing a problem with printing. If you print out an excel document titled 'ABC invoice', the 2050 will print the invoice. If you then print another document called time table, it will print out the ABC invoice again, but not the time table. This behavior has continued even after restarting the printer and reloading the driver. It seems like the original print job gets stuck in the printer memory and then every other print job is one job behind, does that make sense? I am having problems finding solutions online because I don't really know what to call this issue, so any help you could provide would be appreciated....Thanks!
  • framboise Mar 21, 2011
    Thanks for you help but that didn't work. The Spool folder was empty there are no changes to the situation even after restarting the computer. I'm not sure what to do next.
    Genius:
  • 1,570 Answers
Hi
Clear the pending jobs on print spooler
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Posted on Mar 21, 2011
    Hi Benjz,
    Thanks for the instructions. It didn't work though. There were no jobs pending. In fact the folder was completetly empty. I did restart the PC just in case but nothing's changed.
    Do you have any other ideas maybe? Or has anyone else an idea as to what to try next?
    Thanks in advance.
  • Benjamin Jr Singson Mar 21, 2011
    Hi try to uninstall and set up again the printer once more to correct the corrupted driver.
Document not printing excel
Describe u r problem clearly..? Printer not print from u r Computer or only in MS-excel ?
Oct 31, 2013 | HP LaserJet 1020 Printer
I am having trouble printing word documents from my Inspiron 1545 to HP Deskjet 2050
Hi there!
What is exactly problem? You couldn't printing from word documents, can you print from other application such as Excel, notepad, website. If you could not print from other applications as well then your printer have problem. Go to Start - Printer and Faxes: check your printer by right click on it and select properties, print the test page to see printer itself is working with windows or not.
If you could print from other applications but not Word Docs, then your word application have problem. Try to end task it, go to Task Manager and End Task it.
Most of the cases, just restart your computer and your printer to refresh the memory.
Hope this will help. Thanks for reading.
Jul 19, 2011 | Computers & Internet
When i print from excel it is printing multiple pages instead one
check your print preview. Either Excel is set to print multiple copies or the spreadsheet is slightly bigger than a page. Fix the spreadsheet, this is likely not a printer issue.
Mar 23, 2011 | HP LaserJet 1320 Printer
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
LaserJet 5Si printing slow use to be able to hit the print key then the printer would fire away. seems like the printer pauses between pages then prints maybe 3 to 4 pages per minute
Could be software. I have seen the last several Adobe latest version documents take several seconds to print. I have also seen increased print times with MS office 2003 Powerpoint documents.If it is a single page MS Word or Excel document and u are printing several copies of it, you should turn off the collate feature for printing of that document
Dec 05, 2009 | HP LaserJet 5si Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
We have a HP Deskjet D1320 printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete...
I have a HP Deskjet 1300n printer. I can print my email, pictures and items off the internet, but cannot print any word documents or notepad documents. When I print an excel document, I get an incomplete page-the grid lines will print,and text garbage from a adobe program but not all the text. When I do a test print page, I get an incomplete text page, but do not know how to solve this. I have removed and reloaded the printer software-no improvement. There are no new drivers to be installed.
Sep 21, 2008 | HP LaserJet 1300 Printer
LINE 100
If Sale Line 100 is an Excel Template then it is simple.
The Templates are just preformatted spreadsheets which are edited just like any other spreadsheet.
If you mean that you are using the Template to create another document but wanting all the fields to be the same as the Invoice then I suggest the following method:
Copy the Template fron Worksheet 1 onto Worksheet 2.
Add and remove any fields that you wnt to add or remove (Prices would be deleted on this copy and the title would be changed from Invoice to Delivery Docket, etc)
Then (on Worksheet 2) in the fields that you want to be the same - click on the cell you want the same Data in and hit the = sign. Then go to Worksheet 1 and Click on the cell that you want the data to be the same. Hit Enter. This will send you back to Worksheet 2 and you will see that any data entered into the cell in Worksheet 1 will now also appear in Worksheet 2.
Repeat this process for all the cells you want copied from worksheet 1.
When you complete the data in Worksheet 1 (the Invoice) all the data selected will automatically appear in the cells selected on Worksheet 2.
Try this on worksheet 2 select cell A1, type =, then open worksheet 1 and select B1. You will be returned to worksheet 2 and the formula in cell A1 will now read =Sheet1!A1. Enter anything into Shhet 1 A1 and you will see that it appears in the appropriate cell on Sheet 2.
When you want to print off the Invoice and the Delivery Docket - you only have to open each Worksheet and hit Print and a copy of each worksheet will be printed giving you an Invoice and a Delivery Docket with the appropriate info on each printout (eg if you exclude prices from the Del. Docket then after completing all the details in the Invoice will create a Del Docket with all the relevant information other than the prices.
Does this answer your question?
Apr 25, 2008 | Computers & Internet
HP 1020 printing problems
It seems like the problem is not the printer, but your Excel file.
Jul 27, 2007 | HP LaserJet 1020 Printer
124 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
