Question about Eclipse AVN5435 Car DVD Player
My problem the radio system is not operating after i removed the battery
  • 40 Answers
For avn 5435 on the left:press menu and cont ant the same time, while holding them down press menu on the right 5 times
a menu will appear and ask you for a code. you have to call 800-233-2216 and pay $25 for the code. you will have to explain where you bought your eclipse and or know the name of the original owner. if it doesnt match they will not give it to you
Posted on Mar 21, 2011
No sound from radio after i change the battery
try using a scan tool to reset the cpu program in the ECM
removing a battery corrupts that program
it controls everything you mentioned including the immobilizer
as for the radio ,you will need a code to enter as it is the radio anti theft system that has operated when the battery was remove d
Sep 06, 2015 | 2012 Chevrolet Malibu
Tip
How to change a heater control unit/heater control ford puma
Ford Puma
What you will need:-
1.Phillips Screw Driver
2.Depending on what stereo system you have, stereo removal keys.
REMOVAL AND INSTALLATION
Climate Control Assembly/heater control unit/
Removal
1. Standard preparatory measures
Make a note of the radio keycode.
Make a note of the preset radio stations.
CAUTION:
Disconnect the battery negative lead.
2. Remove the radio.
3. Note:The control unit for the heating/air conditioning system, all operating knobs and the air distribution operating switch make up one assembly.
Remove the bezel/control unit.
1 Remove the screws on the top of the unit
2 Unclip the clips either side of the unit
Pull the bezel/unit forwards.
Disconnect the plug.
4. Unclip the air distribution shaft.
5. Remove the heater/air conditioning module and the fan operating switch.
Installation
1. Refit the components in the reverse order.
2. Install the radio.
3. Connect the battery ground lead.
Enter the radio keycode.
Reprogramme the preset radio stations.
Reset the clock.
Carry out a road test to enable the PCM to collect data.
4. Check that the heater/air conditioning operates properly.
on Jan 31, 2010 | Ford Focus Cars & Trucks
Changed the battery in amyt 525i and now the radio does not funtion how it used to
you will have to get the security code for that wireless and insert it before the wireless will operate. When you removed the battery the system thought the radio was being stolen and activated the anti-theft system in the radio.
Dec 26, 2013 | BMW 525i Cars & Trucks
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
How do i replace the batteries in this device?
To install the batteries:1. With the back of the radio facing you, remove the belt clip (seediagram below) for easy access, then remove the Battery Coverby pressing down on the top center and sliding it down from theradio.2. Insert 4 AA batteries observing the polarity as shown. Installingthe batteries incorrectly will prevent the unit from operating ormay damage the unit.3. Return the Battery Cover by sliding it up on the radio. Replace thebelt clip, making sure it locks into place.
To install the batteries: 1. With the back of the radio facing you, remove the belt clip (see diagram below) for easy access, then remove the Battery Cover by pressing down on the top center and sliding it down from the radio. 2. Insert 4 AA batteries observing the polarity as shown. Installing the batteries incorrectly will prevent the unit from operating or may damage the unit. 3. Return the Battery Cover by sliding it up on the radio. Replace the belt clip, making sure it locks into place.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Midland LXT310 2-Way Radio
How to remove radio from 1990 cs corolla
I understand you remove the panel and then for a
1990, it has a handle and you simply pull it straight out.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable. CAUTION
    On models with an airbag, wait at least 90 seconds from the time that the ignition switch is turned to the LOCK position and the battery is disconnected before performing any further work.
  2. Remove the attaching screws from the trim panel.
  3. Remove the trim panel, being careful of the concealed spring clips behind the panel. Remove the trim panel surrounding the stereo 88276p31.jpg
  4. Disconnect the wiring from the switches if so equipped mounted in the trim panel.
  5. Remove the mounting screws from the radio. Remove the four radio retaining screws and pull the unit from the dash 88276p32.jpg
  6. Remove the radio from the dash until the wiring connectors are exposed.
  7. Disconnect the electrical connectors and the antenna cable from the body of the radio and remove the radio from the car. To install:
  8. Reconnect all the wiring and antenna cable first, then place the radio in position within the dash.
  9. Install the attaching screws.
  10. Reconnect the wiring harnesses to the switches if so equipped in the trim panel and make sure the switches if so equipped are secure in the panel.
  11. Install the trim panel (make sure all the spring clips engage) and install the screws. Conmnect the negative battery cable.
  12. Check radio system for proper operation.
Jul 22, 2010 | 1990 Toyota Corolla
Im trying to locate my water pump on my 1995 Acura Legend where is it
Fig. 1: Water pump mounting and bolt torque specifications-3.5L engine shown
The radio may have a coded theft protection circuit. Make sure you have the code before disconnecting the battery, removing the radio fuse, or removing the radio.
1.8L Engines
  2. If applicable, remove the front under panel.
  3. Gradually release the system pressure by slowly and carefully removing the radiator cap. Be sure to protect your hands with gloves or a shop rag.
  4. Drain the engine coolant into a sealable container.
  5. Remove the timing belt from the engine.
  6. Remove the camshaft pulleys and remove the back cover.
  7. Unfasten the five water pump mounting bolts, then remove the water pump.
  8. Remove and discard the old O-ring.
  9. Remove the dowel pins from the oil water pump.
  10. Clean the O-ring groove and the water pump mounting surface on the engine.
To install:
  1. Install the dowel pins to the new water pump.
  2. Position a new O-ring to the new water pump, Apply a small amount of sealant to the O-ring to hold it in position.
  3. Place the new water pump on the engine and install the mounting bolts. Tighten the mounting bolts to 104 inch lbs. (12 Nm).
  4. Install the back cover and the camshaft pulleys.
  5. Install the timing belt.
  6. Fill the engine with coolant and bleed the air from the cooling system.
  7. Connect the negative battery cable and enter the radio security code.
  8. Run the engine and check for cooling system leaks.
2.2L, 2.3L, 2.5L, 3.0L, 3.2L and 3.5L Engines
Perform this service operation with the engine cold.
  2. Remove the front splash panel and release the system pressure by slowly removing the radiator cap.
  3. Drain the cooling system.
  4. Remove the timing belt. Inspect the timing belt for any signs of damage or oil and coolant contamination. Replace the timing belt if there is any doubt about its condition.
  5. On 1996-97 3.2 TL and 1996-00 3.5 RL models, remove the left camshaft pulley and back cover.
  6. On 1997-00 3.0 CL models and 1999-00 3.2 TL models, remove the timing belt tensioner.
  7. Remove the water pump bolts. Then, remove the water pump and sprocket assembly from the engine block. Remove the O-rings from the water passage.
To install:
  1. Before installation, be sure all gasket and O-ring groove surfaces are clean.
  2. Install the water pump with a new O-ring. Use new bolts and tighten the 6mm mounting bolts evenly to 104 inch lbs. (12 Nm) and the 8mm bolts to 16 ft. lbs. (22 Nm).
  3. If removed, install the timing belt rear cover and camshaft pulley.
  4. If removed, install the timing belt tensioner.
  5. Install the timing belt and timing belt covers.
  6. Install and adjust the tension of the accessory drive belts.
  7. Close the cooling system drain plug. Refill and bleed the cooling system.
  8. Connect the negative battery cable.
  9. Start the engine, allow it to reach normal operating temperature, check for leaks, and top off as necessary.
  10. Enter the radio security code.
Hope this helps (remember comment and rated this).
Jun 21, 2010 | 1995 Acura Legend
Replaced factory radio one week ago with
sounds like its wired up wrong, remove the radio unplug the connector and remove the radio, then check all your fuses must have blown one when radio was installed, after that charge battery and with radio removed see if battery goes dead, if not recheck wiring to radio, common problem with vw aftermarket radio,they are installed wrong,good luck,
Nov 16, 2009 | 2003 Volkswagen New Beetle Convertible
I want to change the battery
Unless you Have AoolCodes DEALER IS A GOOD IDEA
Disconnecting/Connecting The Battery
Always stop the engine before disconnecting the battery negative lead and make sure the battery positive lead is isolated i.e. wrapped in a suitable cloth.
WARNING: Radio code saving devices must not be used when conducting work on air bag or fuel systems. It must be noted that, when using these devices, the vehicle electrical system is still live albeit with a reduced current flow.
NOTE: Before disconnecting the battery make sure that the radio receiver/cassette player/mini disc player and compact disc player keycodes are known and, that no data is required from the powertrain control module as battery disconnection will erase any fault codes and idle/drive values held in the Keep Alive Memory (KAM). It is not necessary to disconnect or remove electronic control modules.
Always disconnect the battery before commencing repair operations which require:
  • The vehicle to be jacked up
  • Work on the engine
  • Work underneath the vehicle
  • Arc welding
Alternatively a Radio Code Saver may be used. With the battery disconnected, a Radio Code Saver will allow sufficient current to pass to maintain the radio receiver/cassette player/mini disc player and compact disc player memory, operate the clock and supply the door operated interior lights while isolating the battery in the event of a short circuit.
Reconnecting the Battery
WARNING: If the battery has been on bench charge the cells may be giving off explosive hydrogen gas. Avoid creating sparks, and if in doubt cover the vent plugs or covers with a damp cloth.
Always make sure that all electrical systems are switched OFF before reconnecting the battery to avoid causing sparks or damage to sensitive electrical equipment.
Always reconnect the battery positive lead first and the negative last, ensuring that there is a good electrical contact and the battery terminals are secure.
Restart the clock (where fitted) and set it to the correct time.
Re-enter the radio receiver/cassette player/mini disc player and compact disc player keycodes and preset' frequencies, if known.
Following reconnection of the battery, the engine should be allowed to idle until it has reached normal operating temperature as the stored idle and drive values contained within the powertrain control module have been lost. Allow the vehicle to idle for a further three minutes . Drive the vehicle at constant speeds of approximately 48 km/h (30 mph), 64 km/h (40 mph), 80 km/h (50 mph), 96 km/h (60 mph) and 112 km/h (70 mph) for three minutes each. This may cause a driveability concern if the procedure is not carried out. This will allow the powertrain control module to relearn idle values.
Jun 20, 2009 | 2003 Jaguar X-Type
Removing factory installed radio (trim panels) to install another
CAUTIONOn models with an airbag, wait at least 90 seconds from the time that the ignition switch is turned to the LOCK position and the battery is disconnected before performing any further work.
  1. Remove the attaching screws from the trim panel.
  2. Remove the trim panel, being careful of the concealed spring clips behind the panel.
  3. Disconnect the wiring from the switches if so equipped mounted in the trim panel.
  4. Remove the mounting screws from the radio.
0900c152800927e1.jpgRemove the upper and lower screws from both sides of the radio brackets
  1. Remove the radio from the dash until the wiring connectors are exposed.
0900c152800927e2.jpgExtract the radio with brackets and ashtray out of the dash
  1. Disconnect the electrical harness and the antenna cable from the body of the radio and remove the radio from the car.
0900c152800927e3.jpgDisconnect the wiring harness from the back of the radio, along with the antenna leadTo install:
  1. Reconnect all the wiring and antenna cable first, then place the radio in position within the dash.
  2. Install the attaching screws.
  3. Reconnect the wiring harnesses to the switches if so equipped in the trim panel and make sure the switches if so equipped are secure in the panel.
  4. Install the trim panel (make sure all the spring clips engage) and install the screws.
  5. Connect the negative battery cable.
  6. Check radio system for proper operation.227202e.jpgbb69abc.jpg334d965.jpg3154976.jpg
Good luck....
Nov 01, 2008 | 2000 Toyota Camry
Eclipse AVN5435 Car DVD Player Logo
412 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
