Question about Xerox Phaser 3117
I want to change the cartridge of printer but i d'nt know how?
  • Xerox Master
  • 525 Answers
Just open front printer cover and pull out toner cartridge, then put in new one
I hope this help!
Posted on Apr 21, 2011
It says i have a automatic alignment problem it shows i have ink i have'nt changed the ink since i brought the printer.
It could be that the cartridges are not seated properly in the cartridge carrier or the encoder strip got unseated from its position. Please follow steps below to fix the problem:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. While the printer cover is open, check the cartridge area for a loose encoder strip (transparent strip).
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, re-insert one cartridge first.
  7. Close printer and check for any errors.
  8. If no error appears, reinsert your other cartridge.
  9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 25, 2011 | Lexmark Z2420 Printer
I have a hp laserjet 1515n. doubleing printout problem
I am not sure what printer you have here but if you are having repeat images down the page then it more than likely that you have a faulty toner cartridge. Try changing the toner cartridge first.
If that does,nt solve the problem then you have a defective fuser assembly.
Jun 10, 2011 | HP : HP6L Laserjet Printer
Lines across paper when printing after changing to a new printer toner cartridge
ensure that u r using a hp cartidges
dis problem persists when u r nt using hp cartidges or u have rifilled the cartides
also sometimes when the printhead of the cartideges is defective u face same problem
Jan 05, 2011 | HP LaserJet 2420d Printer
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
When I load paper into machine it does not spool and keeps repeating Out of Paper
it's due to u r nt able to insert the paper properly or ur printer cartridges are nt properly align
Mar 24, 2010 | Epson Stylus CX4400 All-In-One InkJet...
I put new printer cartridges in;left catridges lexmark x6570
maybe the cartridges you put are nt compatible to the printer or not properly place
Nov 29, 2009 | Lexmark X6570 InkJet Printer
Pls what could be responsible for 10.1000 supply memory error in HP laserjet M1522n
it just means that the printer can't read a tiny eeprom chip on the cartridge. 10.10.00 refers to the black cartridge, and you should be able to continue just by hitting the ok button. it should go away with the next cartridge.
Jun 16, 2009 | HP LaserJet M1522nf Multifunction Printer...
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Photos
give your printer a DIAGNOSTIC TEST , is a cleaning test procedure of the ink cartridges, there you should know if you need to replace the ink cartridges.hope this helps AJ
May 08, 2008 | Canon PIXMA MP470 All-in-One Printer
Computers & Internet Logo
73 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
