Question about Intel Motherboard
Computer problem!? Hello there, hope you are well :-) Please can you help? I had no power at all when i switched on my PC and was advised that i probably needed a new power supply, so, i brought a new one (same wattage etc), and i still have nothing happening. Could it be the mother board and is there any way i can test it?? Many Thanks in advance :-)
  • 659 Answers
Is there any led lights on the motherboard? ushally yellow or green. if its getting power this will ushally turn on right away. and make sure on the back of the power supply that its set to the right setting and the switch is flicked over to power it
Posted on Aug 03, 2008
My computer is not run in properly window log on time in stop why ?
Posted on Aug 04, 2008
I'm not getting any power to my lenovo 3000 j series desktop.
Hello, please try the following:
1. First is to check your power supply. Try to look if the power supply is functioning, if the fan turns so it is okay.
2. Try to remove the CMOS battery and put the cmos jumper setting to reset mode.
3. Remove the Memory card.
4. Plug your Computer and standby it for about 3 minutes.
5. Return all the devices that you remove.
6. Switch back to normal the CMOS.
7. Turn on your computer and your done.
Hope it will help you.
Mar 15, 2012 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Schematic for ES450 switching power supply.
we can find this,,when you provide the maker of the power supplies, please..
Feb 26, 2008 | Computers & Internet
I have a Acer Aspire 5253 notebook that just switched off and when booting up only the ON button comes on but the pc does not switch on. Please advise on how to fix this.
Try this
  • Unplug the power cable
  • remove the battery
  • press the Power On Button (on your notebook) for 30-60 seconds
  • Plug-in the Power cable
  • Press the start Button
Hope this help
Dec 24, 2011 | Acer Computers & Internet
Hello i have the problem that my laptop battery is showing that "31% available ( plugged in, not charging) . but when i remove my ac adopter from my laptop it suddernly switch off . what is the...
Try this:
  • Turn the computer off
  • Unplug the computer
  • Remove the battery
  • Plug in the power cord
  • Power on the computer
If it powers up, you have a battery problem; It is either the battery or the charging circuit. Replacing the battery is easy and not too expensive. Fixing the charging circuit on a laptop is not economical.
Hope this helps. I do this for fun & 4 thumb feedback, not $$$
Oct 05, 2011 | Computers & Internet
I have a 2003 Mag Flat screen and I was trying to hook up to a second computer. There is no plug in for electrical like my HP Flat screen. I can plug into computer but cannot figure how to plug into...
These monitors use an external power adapter that plugs into the VGA plug. Look at the the VGA plug that goes to the computer, it has a small round power socket on the back of the plug. Here is a link to a power adapter that will work with the unit.
I hope this helps, if so please rate my solution.
Sep 17, 2011 | Mag Innovision 19" LCD Flat-Panel Monitor...
My LCD's not working!!! but my PC works fine!!
The problem you have is caused by a shorted power supply board. This is a easy repair if you can solder. We have a step by step repair guide posted on our web site at: This should get you back going again. if you have any questions just let us know.
I hope this helps, If so please rate our solution.
Corporate Computer
Feb 19, 2010 | LG L196WTQ Monitor
Ok power went off but now my emachine wont turn on the switch just lights up for an sec or two,please help
I would suggest that you try and check the system with another power pack,
just to be sure that it is not the power supply that is faulty.
This is because what you have describe here is one of the symptoms of a failing power supply,
and It is not always advisable to take a power supply case lightly,
and when it is detected that its the one that is faulty, Just change the power pack OUTRIGHT!
and please don't think of repairing it.
It is not always expensive though, as compared to if your whole system now starts to develop fault because of it.
Hope this helps you out.
Nov 25, 2009 | Computers & Internet
The switches under 3Com 5500G- EI cannot communicate each other
I don't know anything about them, but here's a 444 page pdf on them. Hopefully it will help:
Feb 19, 2018 | 3Com 5500G-EI
My computer lights
i assume you know how to open your pc...
Solution (1)
1. make sure your computer is not plugged in
2. open the side panel
3. remove the memory card
4. plug in you computer
5. switch on your pc. you should hear a beep. this is to check whether your pc is still working.
6. unplug pc
7. re-install the memory card. make sure that it is firmly attached to the memory slot.
8. switch on again. this should do it.
Solution (2)
Try replacing your power supply unit (PSU). faulty PSU may not be able to supply enough power to your motherboard or other peripherals which is attached to your PC.
hope this post can help you :)
Aug 05, 2008 | Computers & Internet
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
