Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Changing ink cartidges in epson 200 printer? How do I move printer head to a postion to remove cartidges and replace
JayBlair
  • 328 Answers
SOURCE: printer
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
  • 32 Answers
SOURCE: Epson Stlyus C86
Printhead and wastes station is clogged, cheapper to replace printer than to repair.
Posted on Feb 15, 2008
  • 357 Answers
SOURCE: Epson printer: print head not moving to replacement position
Unplug the printer when the head reaches the point where you can take out the cartridge.
After you have replaced the cartridge, plug the printer back in.
Good Luck.
Posted on Feb 16, 2009
  • 326 Answers
SOURCE: changing an ink cartridge Epson stylus sx105
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX105-_E
that guide shows how to change the cartridges and no you dont have to wait untill they have run out to change the cartridges
Posted on May 15, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
Epson Sylus R300 Ink Cartidge stuck
Had the same problem and found its a part underneath the cartridges. You have to remove whole cartridge carrier, it's the printer head that can pop up. Easy to pop back down but you have you remove top covers. Good luck.
Feb 17, 2018 | Epson Stylus Photo R200 InkJet Printer
Replaced the ink in stylus sx 125 with genuine epson ink ... and now wont print at all
Perhaps try accessing the menu using the press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge carriage will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then pull out the ink by holding with thumb and first finger and rotating towards you. insert the ink again by pushing in and rotating away from you. close grey cover. now confirm ink replaced as per screen prompt. the machine will run the ink to the print head, takes a minute. then turn off and on and it 'should' work.
Jan 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Lost instructions. How do you change the ink cartidge on Epson sx200?
How do I change the ink cartridges on my new Epson NX 215 printer, I do not know how to move the ink holder.
Nov 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Error code E-90
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Oct 22, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Cartidge problem
Many "compatible" cartridges are badly manufactured or even labeld wrong. These can damage or block the connectors on Epson printers. your best bet is go buy new ink and try them, then if it still dont recognise, you could buy some ink cleaning cartiridges and give them a try - Google "Epson Print Head cleaning" Failing that go buy a new printer - Epson's are real cheap new.
Sep 08, 2007 | Epson Stylus C48 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
764 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
