Question about Dishwashers
How to get to heating element on dishwasher hotpoint fdw60
    Sergeant:
    Novelist:
  • 196 Answers
If you make sure all the water is out of the machine first. Then if you can try lying the machine on its left side. This will allow you to romove the bottom panel, normally just 2 screws at front and 2 at back, this will give you complete access to all the parts in the base. Element will be a silver round part connected in the water pipes.
Posted on Mar 21, 2011
SOURCE: HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
IFIXALL
  • 868 Answers
SOURCE: hotpoint fdw60 dishwasher
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
Posted on May 23, 2008
amgm
  • 32 Answers
SOURCE: location of element
Hi, Hotpoint FDW60 got a concealled element.
You need to unplug and disconnect the dw, lay it flat on its back and remove the bottom tray (depending on the final letter for your model (FDW60G, FDW60P, FDW60T) you might need to remove the side panels and kickboard to release the bottom tray). Carefull with the floater switch. You should be able to locate the element straight away. Replace it and reverse the process.
Cheers
Posted on Feb 15, 2009
  • 25 Answers
SOURCE: hotpoint fdw60 dishwasher, heater not heating water or drying.
If the heater is ok and the wiring is also not burnt out, then the fault will likely be the heater relay on the pcb. (Which means usually replacing the board).
Posted on Feb 28, 2009
heatman101
  • 43501 Answers
SOURCE: hotpoint FDW60 dishwasher. not heating.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 05, 2011
How to change the fdw60 heating element
Hi The element is on the bottom , so if you disconect water and power then turn unit over so it is laying on the front door , you will see the two connections where the two wires connect to the element and also should see how to remove the element at this time , it's not a hard job just takes some time to get to it
Nov 15, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 dishwasher. not heating. How /where do i test the pcb to check if faulty ??
heatman101
Aug 03, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Bosch dishwasher not heating the water at all but everything else is working fine
This needs the heating element checking & replacing if defective. There are also possibly 2 thermal cut-out switches that need checking too. Replace if not working.
Aug 20, 2010 | Hotpoint 24 in. FDW60 Free-standing...
My fdw60 dishwasher stops when it reaches drying the drying light and the salt refill light keeps flashing what could this be
I have the same problem. This means the dishwasher is overheating. Sometimes the plates are too hot to touch and we are loosing the glaze from our crockery. There does not seem to be a thermostat spare part and therefore I changed the heating element but this has not solved the problem.
Nov 12, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dishwasher - not cleaning properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
,vbcbj
Oct 04, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Location of element
Cheers
Feb 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
AQUARIUS FDW60. THA FAST AND DELICATE LIGHTS KEEP FLASHING.
I had the same problem with my Hotpoint FDW60 and read all the online reviews about how baddly made the FDW60 is and after taking it apart I totally agree.
As the warning lights were indicating a faulty heating element I checked it to find that it was not working. I bought a replacement for £43 at my local electrical store (I think they then ordered it online). Taking the bottom off is easy but once off, it is very difficult to actually get to the element, but it can be done. I had to buy new hose clips to fasten the rubber pipe each side too. It has been on twice today and so far so good.
I have read some message boards and have seen that some people have had to replace the element a number of times, so I will wait and see what happens.
Be aware the heating element is not your usual heating element, it looks more like a insulated metal tube: http://www.buyspares.co.uk/cgi-bin/search.pl?query=heating+element+fdw60
Good luck
Rob
Jan 18, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius FDW 20. Not Heating
Yes take right hand side panel off, change heater from there.
Nov 02, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 fast and delicate lights flashing
Heater elements on FDW 60 do not last long at all, I am on my 3rd. You are better of buying a heating element and a decent limescale filter, otherwise it will keep happening. The flow through element builds up limescale, causing the element/thermostat to over heat.
Its a shame as they are quite a good dishwasher. Hotpoint 5 year parts warranty a waste of time. £90 call out charge.
The last one lasted 3 moths before delciates & fast light started flashing.
You can get the elements online for £40
Jan 03, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
