Question about JVC AV-32260 32" TV
JVC AV-25P8-PH TV turns on (the standby mode) with the red light, but when we try to punch in the channel (using either remote or the push buttons on the television itself), the red light becomes green then automatically shuts off. We can't get to work the TV even if we plug it directly on the wall socket, nor unplug then plug it again. Just goes on and on. What do we have to do with this to make it work?
  • JVC Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.....
Good luck.
Posted on Mar 21, 2011
Trying to program Insignia remote to JVC TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Codes for JVC TV are: 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Aug 19, 2012 | Insignia New Original KK-Y284B Remote...
Universal dt008 REMOTE CODE AND INSTRUCTIONS
Direct Code Entry
Aug 19, 2012 | JVC AV-27D302 27" TV
I have a jvc tv model number AV-27530 and a tv guide universal remote i need programing instructions
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jun 22, 2012 | JVC Televison & Video
The TV worked fine on Sunday evening, turned it off the normal way when went to bed. Came down to turn on in the morning and only the red light comes on indicating standby mode. I have unplugged...
There seem to be a problem that is why the television is not coming up and stays stuck on standby mode.
First try to turn on the television using the remote of the television and ensure that the battery of the remote is properly working, you can as well try to push the channel button on the television if the remote does not work.
If it does not come up both by using the remote and pushing the channel button, then it means it is a hardware problem, and that is from inside the unit of the television. Since the standby light comes up, it simply means power is reaching the main panel of the television.
This mainly used to be caused by a faulty or bad capacitor on either the main panel or the power panel of the television.
To check and fix, follow the steps below:
Dec 07, 2010 | Insignia NS-LTDVD19-09 LCD TV
I need to get code for tv
Hello
Three Digit universal remote codes for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Four Digit universal remote code for JVC are:-
Direct Code Entry
Nov 30, 2010 | JVC AV-27530 27" TV
What is the universal remote code for JVC AV27D302
Hello
Four Digit Universal remote codes for JVC are:-
0060 _0026_ 0197_ 0069_ 0247_ 0923_ 0012_ 0065_ 0067_ 0141_0048
Three digit Universal Remote Code for JVC are:-
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Nov 20, 2010 | JVC AV-27D302 27" TV
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
JVC AV-48WP30 48 in. Rear... Problem:
Take the batteries out of the remote control. Press every button 2 times. Then re-insert the batteries. While doing this unplug the TV and hold the power button down for 30 seconds. Then let go and leave the TV unplugged for 3 min. Then turn tv on do a channel scan and then try yhe remote.
Jan 08, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-32260 32" TV Logo
299 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
