Question about Health & Beauty
I have a 3yr old pride scooter, it is fully charged, when switched on lights and horn work, status light flashes, but it will not run
  • 692 Answers
Kay the status light flashing indicates a problem. Count the nunber of flashes and your manual should tell you what the error code means. Also check the freewheel lever and make sure it is drive position. Without knowing the number of flashes I can't tell you what the problem might be. Hope this helps
Posted on Mar 21, 2011
Testimonial: "freewheel lever! thank you very much"
Free micromax x1i charging problam image downlode
Posted on Mar 26, 2011
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Feb 08, 2016 | Pride Health & Beauty
The status light does not come on.The batteries are new and the lights work .The running lights works,but the horn does'nt .
hi Edward, okay if you have no status light ? please verify that ? so no flashing light ?
Did you fit the batteries ? the reason I ask if someone else did it , did you see them fit the batteries because that fault can caused because the batteries have been fitted incorrectly then corrected however it done damage to the controller ....
it well be a wiring issue so check the wiring from the tiller to the frame to the controller, making sure there are no breaks any damaged of any sort ? please update me as I can help you ..
Regards
Rob
Sep 22, 2015 | Pride Mobility Revo 3 Wheel Electric...
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Pride hurricane. Will not move fwd or rev. No beeps when turn on switch
So the status light does not flash ? just a steady green ?,,,
so when moving the throttle lever or wig wag what ever you wish to call it , is there a click from the rear brake located on the side of the motor ???
Regards
Rob
www.gewizrepairs.co.uk
Feb 02, 2014 | Hurricane Pride PMV Mobility Scooter -...
My jazzy pride 614 wont go anywhere when i push the joystick forword a yellow light flashes but its yo hard to see
if it can be pushed then the free wheel locking lever is needing to be put in the locking position
Mar 18, 2013 | Pride Mobility Products Pride Jazzy 614
Pride colt . fully charged batteries but no power to lights indicators or drive
hi, okay have you checked the fuses located on the tiller stem normally located under a black plastic cover ?
Your batteries may be fully charged but the voltage is not enough to power up the controller, sigh of a dodgy charger ? , bad batteries ? ? check the battery voltage , should be at least 24volts
The horn will work as it bypasses the controller logic.
Regards
Jan 20, 2013 | Pride Health & Beauty
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Health & Beauty Logo
435 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
