I saw an Amplifier which says its Frequency Response is 100 HZ to 15,000 HZ. If a CD Player whose frequency response stated as 20 HZ to 20,000 HZ needs to be connected to this Amplifier. If this CD was connected to the said amplifier and if the CD Player gives the input of say 50 HZ to the amplifier and the input of 17 KHz to the amplifier - what will the amplifier do as its frequency range is different from the CD players frequency range. Please clarify
  • 3,400 Answers
The amp will only go as low as 100hz regardless of what input is fed to it.
Posted on Mar 21, 2011
My nx501 says invalid disc when I put a cd in I
Clarion NX501 Owner Manual Installation Manualit looks like this is mainly a dvd player,it does play disks with mp3's and wma files but,not compact disc files,read the manual,try a recorded cd with mp3s,
DVD Player System
Digital Versatile Disc System with CDDA capable
Usable discs:
DVD video disc, Compact disc
Frequency Response: 20 Hz to 20 kHz
Sound/Noise Ratio: 95 dbA (1W Ref)
Dynamic Range: 95 dB (1 kHz)
Distortion: 0.05%
Video system: NTSC/PAL
May 22, 2015 | Televison & Video
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 23, 2011 | Car Audio & Video
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Apr 15, 2008 | Car Audio & Video
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Mar 31, 2008 | Logic Soundlab PLX-520 Car Audio Amplifier
How should I wire up this amp and sub
The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
97 people viewed this question
 Grubhead
Grubhead
