Question about Belling 24 in. IDW603 Built-in Dishwasher
The program selector is not functioning and the door will not close properly. are they related and how do i fix, tks
  • Belling Master
  • 19,396 Answers
Hi.
If the door does not close properly, the door switch may not close contact to timer circuit, and the machine may not do the cycle for this reason. Additionally, a short in the door switch wiring harness may jam the control module.
Before checking control module have a look at the door switch and at the wiring harness inside the door.
Regards.
Ginko.
Posted on Mar 21, 2011
How do I reset the program. It will not start
on ur last wash did it spin ok or where the cloth a bit wetter than normal
Jan 25, 2015 | Candy Washing Machines
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
My dishwasher will not work
Hello
Investigate these four areas if your dishwasher is not working at all:
Power Supply;
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Aug 11, 2011 | Stoves 23 in. Q60DW Built-in Dishwasher
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
2005 grand caravan front heater and defrorst not working ,rear heater is working . i also hear a hissing noice on the passenger side
Just a suspicion: hissing noise comes from failed/jammed/malfunctioning motor to move the door
in the ducting to route heated air to the hoses/ports for "heater" and "defrost."
Problem: failure of motor/linkage to heater/defrost selector door under the dash on the passenger side.
Also sounds like you have not blown fuse to this selector door.
Also - hissing noise could be air being forced against the closed door (which should be open) - in this
case, you'd want to check the fuse to the heater/defroster actuator door.
The rear heater works since its function is not related to the operation of the front heater/defroster.
Jan 02, 2011 | 2005 Dodge Grand Caravan
Dishwasher will not run. I have checked the circuit breaker and it seems fine. does the dishwasher have a reset button?
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Door Switch
Timer Motor
Dec 25, 2009 | KitchenAid Dishwashers
Automatic Door Locks when you start driving
Yes, there is a way to reprogram your car to lock the doors when the gear selector is put into Drive.
Follow this site for a complete step by step re-program of the door locks:
http://www.nialtima.com/automatic_door_locks-113.html
Jan 23, 2018 | 2002 Nissan Altima
HVAC vent selector does not function. Air flow is
THe blend door seems to be stuck. When you change settings from defrost to floor air or, vent, the blend door opens and closes directing the air to the place you want it to go to. I have had some success spraying a lubricating oil such as WD40 under the dash on the blend door. You need to get under the dash with a flashlight to locate it. It looks like a flap. Spray it with a couple of shots of the WD40. Go easy on the spraying as you may be inhaling the fumes. Keep the doors and windows open to minimize the fumes. Wait about 1/2 hour and try the A/C functions. (defrost, floor, vent air)
Mar 09, 2009 | 2002 Buick Rendezvous
Belling 24 in. IDW603 Built-in Dishwasher Logo
238 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
