Question about Ovens
Replacement glass turn table for a Kuppersbusch Microwave, EMW 7605.0 required. Is there an alternative replacement other than a genuine Kuppersbusch turn table?
    Sergeant:
    Novelist:
  • 196 Answers
I have a Kuppersbusch microspeed plus (EMWK9600.0M) was in the house when we moved In. whilst using it in microwave mode I heard a bang and the internal glass door has shattered.
The glass will break if the food being heated is not covered and fat/grease heats up to flash point on the glass or there is a cut in the glass or the food banged against the glass or the glass was stressed by an incorrectly fitting door.
A new door is possibly available or glass.
May 17, 2017 | Kuppersbusch Ovens
Microwave door glass replacement
yes u can refit it normally.but do it carefully.need more help regarding this let me know .
Jun 16, 2008 | Ovens
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
Apr 11, 2015 | GE ZSC2001FSS Advantium Electric Single...
How do i clean the inside glass of a kuppersbusch oven ?
Hello, Make sure the oven is warm, not hot. Open the door and spray the glass with vinegar and water and wipe with newspaper.
Dec 11, 2014 | Kuppersbusch Ovens
Kuppersbusch microwave door glass replacement
Did you resolve your problem as my inner door just shattered and will need replacing? Do you know why yours broke?
Jan 09, 2012 | Ovens
Microwave table not turning
Hi
The first thing I would check is the coupler. Remove the glass tray and pull the coupler up. Check it for any cracks.If the coupler is fine then the turntable motor has to be replaced.It can be easy replaced after the bottom panel removed - just two screws and the wire plug.
Thanks for using Fixya.
Apr 13, 2011 | Ovens
I need to replace the light bulb in my whirlpool self-cleaning oven but I can not remove the glass cover. How do I remove it?
hello,
Here is a solution to go about the glass bellow
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door. Work around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • hope this solution help?
    Thanks for visiting fixya.
    Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Model No MH6150MXQ - 0 Turn table will not
    Hello- The motor has a plastic gear on the shaft that turns glass tray. These can crack or slip off the shaft and not engage the slots on tray. Check to see if gear is cracked or stripped. It may just be loose. Anyway, this part is less than 10$, so replace if it's bad. Let me know if this solves the problem. Have more info if needed-  Thanks- Ed
    Mar 18, 2010 | Ovens
    Replacing a glass cook top
    I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
    Let me know if you're interested.
    Jan 09, 2008 | Ovens
    Message 007 displayed on right display
    My kuppersbusch dishwasher drawer (detachable plate rack piece) is rusty. Where can I find a replacement?
    Nov 08, 2007 | Kuppersbusch EEB 6800.0 JX Electric Single...
    Ovens Logo
    127 people viewed this question
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
