Question about Spidem Divina De Luxe Espresso & Coffee Maker
The machine is not working fully. The water is slow to discharge and the display board states ventilate
  • 40 Answers
Try this open the hot water valve, when the display reads ventilate, push in the knob on the valve, if water is then released then the tap rod assembly needs to be replaced.
Posted on Mar 21, 2011
My machine mark alternativley ventilate and fill water tank. I ventilate and I fill the machine and the message don't dissapear. With this display, I can't make any coffee. My email :...
Remove the bottom of the coffee maker, identify two rubber tubes and check to see if one has come loose or is simply not on tight. A simple reattaching of one of the tubes will work.
Another reason could be draining hole getting clogged with coffee grounds. When this happens it is easily fixed by removing the brew group and overflow tray; find the small drain at the back that drains excess water into the overflow tray and opens it up with a pipe cleaner or tooth pick. Flush out any coffee ground behind that hole.
Hope this helps.
Shane
Mar 06, 2011 | Saeco Spidem Trevi Digital Plus Fully...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Ventilate shows.
try prime water on steam valve couple minuts if you have again message ventilate,that can be two reason,or your flow metar doesnt work or cpu board,but you try first prime water.
Aug 28, 2009 | Saeco Royal Professional Espresso Machine
Machine is a incanto typ sup 021ydr.
Check the tip of the steam wand make sure it is not blocked. If not then press in on the steam knob after opening, if that works then the steam valve assembly needs to be replaced.
Jul 12, 2009 | Saeco Incanto Classic Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Nead help pleace
When it says to ventilate, it is asking you to prime the pump. Put a cup under the panarello wand ( the steamer/frother) to catch the discharged water and press the hot water button (upper left button on my machine). Wait until air stops coming out with the water, usually 3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 15, 2009 | Saeco Royal Digital Plus Coffee...
Machine says ventilate
Jan 11, 2009 | Saeco Royal Digital Plus Coffee...
Ventilate will not disappear from the display,and the machine wont work
the procedure is filling water tank opening side valve that should clear the ventilate if is still there remove water tank apply water pressure with pump in the hole of water tank let me now pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
Spidem Divina De Luxe Espresso & Coffee Maker Logo
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
