Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson Stylus DX 8400 All cartridges are recognised but the blue will not print at all, tried new cartridge, no change.
  • 29 Answers
First, did you make sure all the adhesive tape was removed from the cartridge? Second, try printing a test page or preforming an alignment (or cartridge alignment--same thing). You should be able to do this by accessing your printer utilities or setup software that came with the device. Sometimes there's an actual button or menu screen on the device that will let you do it that way.
If all else fails, reinstall the drivers that came with the printer and that should take care of it.
Posted on Mar 21, 2011
Epson 2100 will not recognise new cartridges
Change ink tank using "How to..." at Epson status monitor. Check contactor that connected to ink tank chip at carriage. Other possibility is CSIC board (behind the contactor)
Jan 21, 2013 | Epson Stylus Photo 2100 InkJet Printer
All ink cartridges full but wont print black, dx 8400, please help
try to perform a head cleaning process for a few cycles then try to print again... this may also depend on how long was the printer been stored for it to have clogged nozzles
Jul 11, 2011 | Epson Stylus DX8400 All-In-One InkJet...
Epson stylus dx6000 error message e-02 have tried
Hi
Chances are the mechanism to recognize the ink cartridges is already damage and it may cause a lot having it replaced. I suggest to get a new printer instead specially if you have tried reseating the ink cartridges several times and won't work still.
Thanks for using Fixya
Oct 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus CX5500- Changing/Installing Cartridge (BIG) problem
they are proper mardy machines only happy when using original epson cartridges
Sep 20, 2017 | Epson Stylus CX5400 All-In-One InkJet...
EPSON Stylus S20 print cartridges not recognised.
Try reinstalling cartridges make sure you remove the yellow strip.Ok turn your printer off and back on while installing cartridges ,if this dosen't work disconnect printer cable then turn printer on then off reconnect cable turn on again also disconnect power to printer then reconnect if all fails call Epson and your warranty may cover this
Aug 27, 2009 | Epson Stylus S20 InkJet Photo Printer...
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
It sounds like you have incompatible cartridges for your printer... Some folks have reported that disabling the Status monitor and turning the printer off/on, plus rebooting the computer can solve this but that's just something I've heard.
You may want to double check with the ink supplier that they have provided the correct cartridges for your DX rather than a CX model.
May 17, 2009 | Epson Stylus DX8400 All-In-One InkJet...
I've got the Epson Stylus DX 8400 printer. when I put the cartridge,this message come up: "ink cartridges cannot be recognized." txs
I had the same problem too.  I went to the Epson website and they gave instructions to shake the cartridge 4-5 times prior to installing.   It worked!!!  I tried alot of things before I saw that I needed to shake the cartridge.  Definitely give this a try if you haven't already.
Dec 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
Dec 21, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus rx 425, just cahnged catridges and printer wont recognise this, catridge red light permanently on. help! printer wont recognise cartridge
Try to left up your new cartridge, and reinstall it. chances are your installation of the cartridge is just loosened. If your printer still won't recognise your print cartridge, there might be a problem with your printer motherboard in recognising your cartridge.
Apr 08, 2008 | Computers & Internet
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
572 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
