Question about Sony Ericsson Walkman® W995 Cell Phone
Please help - my phone won't charge at all when i plug charger in (i have 2 chargers and neither works), however the headphones work perfectly. what is the problem ? thanks - avril
  • avril_paton Mar 22, 2011
    hi walesrumi - thanks very much for your assistance and sound advice - that 's exactly what it was. I was able to take to a local repair shop and have the charging port replaced - many thanks, avril
  • Sony Ericsson Master
  • 6,993 Answers
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Good luck.
Posted on Mar 21, 2011
Testimonial: "thanks for your help walesrumi that's exactly what the problem was. i took my mobile to a local repair shop who replaced the charging port in 15 mins"
Camcorder not working without charger plugged in.
hi if you have the charger plugged in the camera the you have power to work it, if you unplug the charger and it dose not work, the I think the battery is not charged fully or it is no good after being left to long, check to see if the battery is charged. I hope this helps you, please let me know.
Mar 30, 2014 | Sony DCR-DVD602E DVD Camcorder
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
WILL NOT CHARGE I HAVE TRIED TO CHAGE IT BUT IT WILL NOT CHAGRE
well if it won't charge then it could be the batteries are too low for the charger to pick up or the charger is not working. If you have a voltmeter set it on 200 vdcand plug it into the 2 outter holes of the charger port located under the front of the joystick. Without the charger plugged in you will read the battery voltage and it should read 25-27 volts fully charged Now plug in the charger and the meter will be reading the charge voltage and it shoud be 27-30 volts. If you are reading 27-30 volts with the charger plugged in then the charger is working Hope this helps you
Apr 22, 2011 | Jet 3 Ultra Power Chair
Does not get charge,plug in the wall charger and does not work, use the same charger in other lg phone and works perfect.
I think you have to bring it to an LG Service Center or a "Certified" Service Center to look into your phone. I think your charger jack is broken or loose that is why its not charging.
Hope this helps! -jayps
Mar 09, 2011 | LG KC910 Renoir Cell Phone
I have the Verizon LGVX8350R phone, it works perfectly but the only thing is that it will NOT charge, I just bought a new charger from walmart 3 weeks ago so its brand new. I did drop the phone on a...
Hi, you will have to test for both to be sure which is faulty.
You can use another charger to test if it will charge or you can use the charger on another Verizon phone to check if the charger is working.
After that, if the charger works, that means the charging port that you attach the charger to the phone will be the problem.
You will need to replace the charging port.
Take care.
Jun 22, 2010 | LG VX8350 Cellular Phone
Problem with charger headset port. it became loose.
ok im having the same problem, im thinking of getting a new charger and or buying a new charging connector for the phone (where the charger/headphones plug into. You can get them on ebay for about $4 US.<br /> hope that helps?
Jun 22, 2010 | Sony Ericsson P1 Cellular Phone
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Insignia Bluetooh Headphone won't turn on. but can charge
Well i fix it putting on power and pressing both volume buttons for 15 seconds. Then he turned on with no problems
Mar 22, 2009 | Insignia Bluetooth Wireless Headphones...
Sony Ericsson Walkman® W995 Cell Phone Logo
459 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
