Question about Sony Ericsson Walkman® W995 Cell Phone
Hi i'm having trouble charging my phone (sony ericsson w995). i have 3 chargers and when i plug each in the phone does not charge, however the headphones work perfectly well in that I can listen to music and speak to people i've called. can you advise what the problem may be. many thanks - avril
  • Sony Ericsson Master
  • 6,993 Answers
I think you have asked this question previously.......... Same answer.
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Good luck.
Posted on Mar 21, 2011
Charging error.stop charging my sony ericsson k800i
As if your using sony ericsson K800i some mobile phones as this problem as myself also faced the same problem sony ericsson mobile shows this error if you charge your mobile using connector or unsupported charges.You visit your nearest service center of sony ericsson and ask then to give branded sony ercsson charger for your mobile.After taking that charger you will not face this problem any more..your mobile is just perfect as new.Your connector or charger is having some problem with it. Charger may cost you around 300 rs. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Sony Ericsson K800i Cellular Phone
Hi sir this is Anbarasu from Dubai. i purchased Sony Ericsson w995 last year October.its working good condition up to last month. Feb 2011 i had one problem with that mobile when i plug the...
Hi There,
Sorry to hear about your problem but I'm here to help!
It is fine to charge through your laptop.
If the problem persists then call Sony Ericsson.
Yours Sincerely
Lewis
Mar 28, 2011 | Sony Ericsson Walkman® W995 Cell Phone
My t715 sony ericsson device has a charging problem. every time i plug it in it seems to charge for about 5 seconds and then it displays "charging problem please remove charger" message and stops...
i have ah problem my t715 sony ericsson the problem i removed this charging pin the leg broken so i need solution my unit... can any one to give me solution charging jumper or diagram this charging pin!.....
Jan 30, 2011 | Sony Ericsson T715 Cell Phone
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Hi ive got a sony erricson w890i and when i plug charger or any other lead in its a bad connection (wont charge) is there a way i can clean contacts @ if so how ? regards
Hi,you can use a brush and a methylated spirit to clean the sport where you plug in charger.
But after cleaning,if not still charging, you can test charger with another phone, before replacing the charging port where you fix in the charger.
Take care.
Jul 04, 2010 | Sony Ericsson W890i Cellular Phone
Trying to charge my sony ericsson k800 mobile and it won't charge. Cannot get 'optimised charging' to appear. Battery now completely flat
Hi, you will need to get another charger. Charger might be faulty and will need to be replaced.
If after replacing charger and still does not charge, then the charging port where you plug in the charger is damaged and needs to be replaced.
Take care.
May 20, 2010 | Cell Phones
Sony ericsson W901i wont charging
listen whereu part the charger pin that is damge need to replace that part then it will be work
Jul 07, 2009 | Sony Ericsson W910i Cellular Phone
When i m charging.. it pops up a message saying that charging error, don charge.. wat's the problem?? my phone is w910i
Hi xue,
This problem occurs due to fault in your charger, The some problem came for me once...
  • try replacing the charger with the ORGINAL Sony charger
Note:Don't use a charger that was manufactured by anyone but Sony Ericsson
Enjoy ! Rate
Vinod Kumar Jayarajan
Jul 01, 2009 | Sony Ericsson W910 Cellular Phone
No power
Does the phone charge when you plug the charger in?
Jun 23, 2008 | Sony Ericsson K610i Cellular Phone
Phone charging
if you have a correct charger then the problem might be in your phone. i request you to give your phone to an authorised dealer. because the charging point in your might have broken or bent.
Jan 06, 2007 | Sony Jabra Earbud Headset - Ericsson T610...
Sony Ericsson Walkman® W995 Cell Phone Logo
356 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
