Brivis wombat 2P 20 will not ignite. The pilot has gone out and will not come back on. Have tried to turn off and on a control panel. Gas supply and power supply is good... what else should I look at? I can not find ignite button
5 Suggested Answers
SOURCE: Air blowing out - Pilot on but no heat.
Possibly overheating or previously overheated, these units are also prone to control box issues usually a buzzing noise at the unit it present if this is the case.
Posted on Apr 28, 2010
reyjoshua07
  • 1157 Answers
SOURCE: brivis buffalo 85 EMS .
Hi redrosebulld,
If the EPRL light still flashes most likely the thermocouple has worn out. The thermocouple is a safety device which stops the gas from flowing. I will recommend to consult an authorized repairman to check the thermocouple and also the injector.
Hope it helps.
Thank you for using FixYa.
Posted on May 20, 2011
  • 81 Answers
SOURCE: Brivis gas heater - Wombat
Take fan apart - easy. Clean with WD40 and then oil with 3and1
Works on all fans.
Posted on Jul 19, 2011
  • 3291 Answers
SOURCE: pilot light is large and
blocked pilot , lack of air so it burns yellow needs blowing out with air line or can of air , or undo and clean pilot .
Posted on Jul 26, 2011
Can we turn the heat off 2-3 rooms with this brivis wombat 92 gas heating system - heating just the parts of the house we choose.
You could freeze water pipes if bathrooms are connected to those rooms - on a cold winter day (depending where you are). All gas appliances should have a shutoff valve. Shutting that off may screw up the main controller - it won't get the proper signal that the flame started ok.
Aug 24, 2014 | Heating & Cooling
Brivis multiplex he20e
MPS HE20E is a gas heater. So the unit should need a pilot to be re-ignited. This will happen automatically once you press the ON button on the controller. Assuming the gas supply is normal this should happen immediately. The unit attempts re-ignition 4 to 5 times but if the pilot does not turn on it will display an error code on the controller. Take extreme precautions when dealing with gas appliances. Make sure you call a technician if unsure.
Aug 21, 2014 | Heating & Cooling
Brivis wombat 2P 20
love to know how you went , i have a similar problem with the same unit.....
May 29, 2013 | Heating & Cooling
Brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Jun 12, 2012 | Heating & Cooling
Pilot light is large and yellow on the brivis 92 wombat
Jul 25, 2011 | Heating & Cooling
Brivis gas heater - Wombat 20 - fan doesnt seem to be operating at full speed
Works on all fans.
Jul 15, 2011 | Heating & Cooling
My brivis wombat 120 igniter won't work so I can't light the pilot
I have a brivis wombat 120. When room temperature is lower than required temperature, it starts to fire up and sends heating air. Now, it does start firing. If I increase the temperature testing, you can hear ant click sound from heater, but no firing. Can anyone help
Mar 26, 2011 | Heating & Cooling
Apr 28, 2010 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
