Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic Polarizer Filter
I have the same model tv, and I am experiencing the same problem.
Is this something that a non-technician can replace, or do I need to bring it to a service center?
Thanks,
Rich Mehner
rjmehner@aol.com
  • 44 Answers
Service center.
Posted on Aug 22, 2008
My quantaray polarizer won't unscrew from the lens. How to remove?
First, make sure you're trying to turn the half closest to the lens. Polarizer filters are designed to turn freely; one half screws onto the lens and then the other half turns free.
Second, don't force it. If you think something's about to break, STOP!
If you can't unscrew the half closest to the lens, try putting a rubber band on it. Wrap the rubber band around that portion of the filter to give you a better grip, then try turning it.
If you have a jar opener, try using that.
A good camera store will sell filter wrenches. One of them should be able to remove the filter. Or take your lens to the store and have someone there remove it with their filter wrench.
Jan 09, 2014 | Quantaray 77mm Linear Polarizer Filter...
A screen comes up and says time to clean air filter, Where is the air filter located?
I just experienced the exact same thing. The tv will shut off if it gets too hot, and a clogged air filter will make it too hot. My tv is still under warranty, but I watched the technician do it. He removed the front and back part of the tv. He got down to the bulb enclosure in the rear of the tv, which is where the filter is located. He used my dirt devil and a brush to clean out the filter and the whole general back of the exposed tv. The he put all the pieces back on the front and back of the tv. Hope that helps!
Feb 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Yellow tint
Hello. Here's the visual key to remember about projectors--LCD panels show their colors like this: RED lcd panel displays cyan onscreen(baby blue); GREEN lcd displays purple; BLUE lcd displays yellow. ( You now know where the displayed dust is!) The problem is most likely a burned blue lcd or polarizer filter in front of the blue lcd panel. This occurs when the dust filter isn't cleaned regularly or properly and heat builds up--yes, enough to "cook" the lcd panel or actually cause a burn to develop on the polarizer. The polarizer is just like a lens in a pair of good sunglasses. It is a small, extremely thin, pane of glass with polarizer material glued onto one side. When burned, it causes a "shadow" effect--that enhances the display of that particular color--in this case, yellow.--Hope I was of assistance!---Rick
Dec 30, 2009 | Panasonic PT-AX200U Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
I have a big green and blue circle on my screen
You are facing this problem due to a burnt polarizer filter just past the blue filter for the blue chip.
This TV has a three chip design with red, blue and green chips.
Get new polarizer for your tv from panasonic .
Mar 02, 2009 | Panasonic PT-50LC14 50" Rear Projection...
LCD Polarizer
Hi Druaga
If I were you I would rather send it i for repair as this is a VERY delicate process.
There is about 6 polarizer panels in the prism and all of them will have to be taken out when replacing one , the problem is not taking them out , but the replacement is an absolute nighmare !
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Cracked glass on front glass
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
Nov 05, 2007 | Televison & Video
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
253 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
