Question about Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop
Hi, I have a dell 4300 dimension that won't boot past the bios screen. When powered up, the motherboard displays a solid green light and a solid amber/yellow light?
  • David Petry Mar 21, 2011
    Your owners manual should give you ome direction on what the problem is, it has a section that vaguely explains the light configuration. Do you have a manual? Let me know at "add a comment"
    Dave
  • 3,940 Answers
You need to post the Power LED and Diag LED status from the rear of the computer, as they have information on why the system isn't booting.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Posted on Mar 21, 2011
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My dell dimension 4300 won't boot into windows. on the advice of my daughter, I downloaded malbytes and it got into a fight with my anti virus and crashed my computer. all 4 diagnostic lights on the rear...
get a new hard drive ( solid state not a disc drive unit)
install win 7 and it will be alright
use kaspershy anti virus for security and don't listen to your daughter
the hard drive was probably on the way out before you did the download
May 29, 2017 | Dell Dimension 4300 PC Desktop
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
4400 dimension dell power light is light green solid, motherboard is solid green but cpu will not power up
Refix RAM memory.
Pull cmos cell for 10 minutes so all settings defaults.
Reconnect ATX power connector from smps to motherbord.
Also change your smps .SMPs is on back side of cpu on top it is square box.
Also check that cable from cpu power switch connected properly to motherbord power on/off pin.
You can test motherbord with power on /ogg pin ground power pin withg any metal it is in corner of motherbord.
Let me know if you need more assistanse.
Thanks.
Aug 26, 2009 | Dell Dimension 4400 PC Desktop
Computer will not boot
Hi Zany913,
3 and 4 solid green lights indicate that the memory is detected but there is an error. First reseat the memory modules. Then try one at a time.
If nothing happens, I'm afraid you'll need to call dell for replacement RAM.
I hope this helps,
Adam
Jul 13, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 4300S (Refurbished) (4300SB8BZ411) PC Desktop Logo
160 people viewed this question
Alun Cox
