If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
SOURCE: WHIRLPOOL OVEN +G2P61F
Remove cover at rear of oven compartment, there you will see the element.
Undo fixing screw(s), carefully pull the element towards you, remove wires, be careful not to lose them inside ,and fit onto new element.
Refit element and rear cover.
Plz rate my solution.
Thanks.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
SOURCE: I have a Whirlpool AKZ161/ix/03 double oven in
If it is fan assisted, and the fan is working o/k, then the chances are it is the element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Normally a straightforward repair
MAKE SURE POWER IS OFF !!!!
Please rate my solution.
Thankyou.
