Question about Sharp Office Equipment & Supplies
Sir, my sharp fax model FO-50 , my problem that ,i do start power , display show-polling refused and so my pro paper is no send . pl help me
  • 2072 Answers
SOURCE: Hard reset to clear paper jam error
Most likely you need to carefully go through the paper path and look for the locations of all the paper path sensors.
You probably have one stuck on the frame or a spring came off the flag and its not actuating properly.
Follow the paper path carefully from the feed rolls out to the exit. I am sure you will find a sensor not operating properly.
Actuate every one and make sure they have no resistance and that they return to the proper position.
Posted on Mar 01, 2008
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
  • 48 Answers
SOURCE: sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
  • 48 Answers
SOURCE: can send but can't receive faxes.
Make sure its on standby auto not manual.
Posted on May 28, 2009
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO 4400 full memory after power surge
Try holding down the stop and start keys while turning the power on and see if that clears the problem.
Andrew
Mar 16, 2009 | Sharp FO-4400 Fax
How do you send a fax with a fo 760?
It asn't my fax, I as doing it for a freind. I own mainly HP products and I gotta tell you the online help from HP is very good, after tying to find out just how to fax a peice of paper from sharp I would never buy a sharp machine.Regards Paul.
Dec 14, 2008 | Sharp FO 760 Plain Paper Thermal transfer...
Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
Problem
Usually, you can just leave the thing unplugged- from the power supply- for a while and clear its memory. There may also be a reset button on the machine, look for it near where the ports/connectors are, and hold it down- most devices will flash a light or beep if the reset is done properly.
May 23, 2007 | Sharp FO DC600 Plain Paper Laser Fax
347 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
