Question about Cameras
Hello there, Before few days my Samsung jet2 (S8003) was drop from my hand and unfortunately it's fall in full water of bucket, after that i removed immediately & made the phone switch off after two three days i cleaned every external part with hair dryer & after 8 days i started phone it's working fine but just camera flash light is not working
    Master:
  • 324 Answers
You were very fortunate! Your quick thinking and the very clever action plan that you put into play saved your Samsung from complete failure! My hat is off to you!
The bad news is that your flash is probably gone for good. Count your blessings and enjoy your phone with the knowledge that you were able to save it. I would advise against going back and trying the flash again and again because this is the part of your phone that requires the most current, and whatever component failed could under demand cause a "cascade failure" and kill the phone for good, wiping out your most excellent save.
Posted on Mar 21, 2011
Cannot get rid of "ice off" light. any ideas please
When ICE OFF blinks on the display panel, reinsert the bucket and/or make sure it's installed properly.- When the door is open, the Ice and water dispenser do not work.- If you close the door hard, it may cause water spilling over the ice maker.- To prevent dropping the ice bucket, use both hands when removing it.- To prevent injury, be sure to clean up any ice or water that may have dropped on the fl oor.- Do not let children hang on the ice dispenser or on the bucket. They may get hurt.- Be sure not to put your hand or any object into the ice chute. It may cause personal injury or damage mechanical parts.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.fridge-manual.com/manuals/samsung/Samsung_RSH7ZNRS.pdf&ved=0ahUKEwiwosOus_DOAhVHKh4KHTsECOEQFggiMAI&usg=AFQjCNFRNinR9EZaKSTZcYUjmD6PwdRcTw&sig2=GIUE1SA4LRL2w84ibu5kEA
Appliance 911 Sea Breeze
Aug 08, 2016 | Samsung RSH7ZNRS Stainless Steel 513L...
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
Haier 45-pint dehumidifier unit cannot be turned on. It has been running fine last few days.
The first thing that comes to mind, is have you emptied the water collection bucket recently? If so, be sure that the bucket was properly reinstalled and is making contact with the bucket safety removal switch.
If you haven't emptied the bucket in the past few days, it may simply be full and will not start until it's emptied.
Hope this helped you and thanks for choosing FixYa.
Sep 13, 2011 | Haier 45-Pint Dehumidifier
Our disposal is full of water, and will not drain down. we had orange peels in there, which seem to not be in there any longer, but the water will not drain out of the disposal. We have a Badger as well.
Take apart P-trap located under sink.
Take photos of everything before starting so things go back easy.
Remove stuff from under sink, get some old towels, and put bucket under sink to catch water.
Loosen both nuts on P-trap and it will fall loose.
Turn on water and turn on disposal for a moment to see if blockage will fall down into catch bucket.
If disposal is still blocked, remove tailpiece connected to side of disposal and then clean out disposal with coat hanger, and/or plastic pipe that is duct-taped to shop vac hose. For a real mess, turn on the water and run disposal to clear blockage while tailpiece is off.
Clean and reassemble parts.
I use rectorseal for all tubular joints so they will not leak.
For re-assembly, I wrote tips with photos from days when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Apr 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Im having no signal on my samsung jet s8003
same as me exactly - signal fades away after less than 5 mins .
Have done the phone reset as detailed above but no joy
anyone help ?
Oct 18, 2009 | Samsung Jet S8000 Cell Phone
My phone Samsung GT-S8003 is stuck on Download mode - GT-S8003
i have todat repair my smsung gts8003, i have relpaced main and sub pcbs, lacd and touch screen now it is howing download mode gt-s8003, what is the solution for this
Oct 18, 2009 | Samsung BlackJack II Smartphone
HTC diamond dropped in water
Try using a hairdryer on it. Open it up as far as you can without voiding your warranty. Don't let it get too hot but the moisture is inside and you may be able to get it to dry out in a couple of days.
Feb 08, 2009 | HTC Touch Diamond Smartphone
Bucket full light will not go off and unit will not operate (there is no water in the bucket).
The bucket full light is controlled by a manual 'float' switch in the bucket itself
-when the water level rises...it lifts the float ...turns on the light and does not allow the unit to operate because it believes it is full.
It is very common for the 'float' to gets misaligned, hung-up, etc. when you remove and re-insert the bucket. Sometimes the 'chain' gets twisted, turned...which does not allow the float to ...float...rather it is 'hung-up' which indicates it is 'full'...when in fact it is clearly not.
To check this:
  • remove bucket from unit
  • look into the top of the bucket opening to locate the 'float'...generally 2" round plastic ball on a shaft, (or chain)
  • softly cup the float in order to lift this up...with the unit stilll plugged in...to see if the light goes off...this is very likely
  • then be sure that the float mechanism is able to freely 'float' in the space....i.e. you are trying to simulate the impact of rising water levels in the bucket
  • as it rises (in your hand the machine will turn off/light on...as it drops....the light shuts off, allowing the machine to run (when humidity levels demand it)
  • then re-install the bucket....being very careful to lift the float, while you insert it...there is generally a little nack to it...but you quickly learn how to do it easily (I just reach into the space...cup the float...put the bucket on an angle...slide it in....release the float into the bucket...(remove hand)...then finish pushing the bucket into place
-hope this helps
Nov 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Cameras Logo
48 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
