The unit has failed, How do I open cover to see if can find what to fix?
  • Televison & ... Master
  • 17,130 Answers
Whatever be the unit it is important that the make/model is specified so that a solution can be thought of. Also if this is a power failure you need to check the power supply unit.
Normal covers of TV's are opened by removing the holding screws of the rear covers.
Look for screws, use a good light to check.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Mar 21, 2011
Canon iR2318L digital copier/printer is showing error code E000007-000 on the LCD screen for this reason the machine is failing to copy/print. Pl. give me solution.
hello,
you need to change the fixing film in fixing unit! The fixing film is worn out!
There is no reset for these type of error! Call service!
Hope that helps!
Jun 18, 2011 | Canon Digital Copier/Printer
Error code e007 on canon imagerunner 210s
that is code for damaged fixing film u will need a technician to replace the fixing film. or replace fixing unit( for that, open the front cover; open screw of down left side small cover, remove cover; detach connection on the upper left side.remove earthing screws and in the upper centre, fixing unit mounting screw. release feeder leaver oin right side.open left door, slide out fixing unit replace with a new one and revert whole process.)
Feb 07, 2011 | Canon imageRUNNER 210S Copier
Show error2200
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. Source(s): http://support.lexmark.com/index?page=co…
Apr 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
How do I open the case of a Garmin c330? Please
To open a Garmin c330 gently pry the silver front cover off by starting at the Garmin Logo location. A thin blade or small screw driver will work well. The silver cover has molded snap-in clips that pop out from the main case. Once the silver cover is off, remove the 4 screws and the case will open. My display was not working, I fixed the problem by adjusting the display's ribbon cable at its connector.
Jul 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Won't start
Sounds like your units cover safty switch has failed. the unit thinks the door(cover) is open(off) If you can find the switch you should be able to bypass by just shorting the wires together
May 31, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Mar 03, 2009 | Sharp AL-1641CS Laser Digital Copier
Laser unit
Once a Laser unit has failed there is no was to fix it with out replacing the laser unit, the polygon mirror motor or associated parts (depending what has failed).
To access the laser take down the front cover (the one where you add toner) and remove it. The plastic cover around the toner/drum unit also needs to removed. Its the black unit behind, it will slide out after you have disconnected it.
Feb 19, 2008 | Ricoh Aficio 450 Copier
SAMSUNG CLP 500
The order iin which you open and close two of the covers is important, as there is an interlock between two of them. This can (and does) get damaged.
The toner access door is the first one you open, THEN the top cover (the one that gives access to the Transfer Belt and Drum.
Make sure the Drum unit is properly pushed into the printer, and that the Transfer Belt is lacated properly AND the two locking levers fot the Transfer Belt are in their locked positions PROPERLY.
THEN close top cover - you shouldn't need to force it.
Followed by the Toner access door.
Yes check the duplex door too !
If this fails it is likely to be a broken case part, or failed sensor.
Dec 26, 2007 | Samsung CLP-500 Laser Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
